Vtec issue
Old Jul 22, 2010 | 06:13 AM
DC2tuner86's Avatar
Icon6 Vtec issue
i have a 95 Gs-r, we bought a hondata s300 socketed to a p75, plugged that in with the base map. The vtec on switchin over on the computer but the CEL is on throwing a code for "Vtec spool" and the Vtec doesnt engages. At the meanwhile we throw the factory p72 ecu back in the Vtec engages but my tuner told me I have no Vtec...but it does crossover. Could it be the Solenoid?
Old Jul 22, 2010 | 06:15 AM
rickyracer's Avatar
Default Re: Vtec issue
no... cause it works with the stock ecu....sounds like a wiring issue...or maybe something wrong with the s300...
Old Jul 22, 2010 | 10:45 AM
DC2tuner86's Avatar
the p75 s300 uploads and reads everything in the car...can u elaborate what you mean by something's wrong with it? 2nd I was gonna try doin a jump harness...or just buy a solenoid which is $175 at the dealer..
Old Jul 22, 2010 | 10:55 AM
rickyracer's Avatar
it's not the solenoid cause you said when you put back the stock ecu everything works fine...you have to check the socket on the ecu and make sure that it has signal...even tho the ecu says it works doesn't mean it really is working...and most of the time if you get the check engine light for that code...it's disconnect...
Old Jul 22, 2010 | 05:25 PM
DC2tuner86's Avatar
ya figured that much that it wasnt the solenoid, we talked to the tuner in Innovative Motors Works, he said I need a harness to activate the non vtec base ecu to vtec since the p75 ecu is non vtec
flipstylez86
Jul 15, 2010 07:52 PM
dougk1401
Dec 7, 2009 08:55 AM
rorik
Engine Management and Tuning
Jun 14, 2008 05:36 PM
MugeNinja
Dec 29, 2005 09:50 AM
tuckin15s_8315
Sep 28, 2005 09:35 PM
