Gsr Question on using nitrous
Old Jul 17, 2010 | 02:14 PM
OrangeTeggy's Avatar
Default Gsr Question on using nitrous
Looking to use nitrous for my 97 integra gsr, b18c with bolt ons.
I have read that wet kits are the way to go , Also have read you want to use a dry kit if your not using a 70 + shot. Kinda confussed on which to believe was wondering if i could get some help. Also would I be able to use my chipped ecu or would I have to run stock p72 ecu?
Old Jul 17, 2010 | 03:26 PM
racebum's Avatar
Default Re: Gsr Question on using nitrous
a chipped ecu tuned on and off nitrous would be ideal. a dual map setup with save you engine with larger hits since you can tune the timing and AF. on an integra i would really really suggest a wet kit, the 240cc stock injectors don't have enough oversupply to run a dry kit with more than maybe 20hp. you could run a 50 shot on the stock ecu with more fuel ala wet kit but should have a wideband in the car at all times. going lean is what really kills nitrous cars
BlackRocket
Oct 9, 2004 07:48 AM
af97civic
Apr 13, 2004 05:41 PM
TO_SLOWGSR
Feb 19, 2004 04:01 AM
blacklude
Oct 14, 2002 01:57 PM
NeedMOPower
Jan 8, 2002 12:15 PM
