b20b into a dc question
Old Jul 17, 2010 | 07:28 PM
efnoobie's Avatar
Default b20b into a dc question
ok i know this topic has been covered before but i cnt seem to find any topic for it.. ok im a noob but i got a b20b and my question is. the part where you mount the driver side engine mount seems to be shorter and the bolt is fatter should i swap over the one from b18?
and second question my b20b dipstik is longer than b18 one.. it might not clear the hood.. should i cut it? or how to i change the one from the b18? or can someone show me link of a full swap guide. thanks H-tech
Old Jul 17, 2010 | 07:44 PM
EHondaJDM's Avatar
Default Re: b20b into a dc question
us the b18 mount and bracket for the mount
the tube for the dipstick can be pulled right out the block just replace the tube and dipstick with a b18
the tube might be snug, use some visegrips to wiggle it out
Old Jul 17, 2010 | 07:48 PM
94dxcoupe's Avatar
^^ Like posted above... Use the 3 bolt style mount and bracket from your B18
http://www.hamotorsports.com/2boltvs3bolt.html
Old Jul 17, 2010 | 08:41 PM
efnoobie's Avatar
got it thanks guys..
Old Jul 17, 2010 | 08:46 PM
EHondaJDM's Avatar
what head you using?
Old Jul 17, 2010 | 10:37 PM
efnoobie's Avatar
stock head.. just running stock b20b maybe move on to b20b-v
Old Jul 18, 2010 | 06:23 AM
EHondaJDM's Avatar
you gonna try running that mammoth manifold off the b20b?
im waiting to see someone try that out
Old Jul 18, 2010 | 08:38 PM
efnoobie's Avatar
i dont think so.. imma run my ls manifold..
Old Jul 18, 2010 | 08:39 PM
efnoobie's Avatar
question cars running but bugging down do i need to tune it in some way?
Old Jul 18, 2010 | 08:51 PM
mouab18c1's Avatar
You need the proper ecu for it.
Old Jul 19, 2010 | 10:14 AM
EHondaJDM's Avatar
depends on what u mean by bugging down
check your timing
if your running a stock LS ECU you should be fine
Old Jul 19, 2010 | 11:38 PM
efnoobie's Avatar
car starts up fine but wen u press the gas it bugs down 1st and runs.. i reuse the intake manifold gasket but the thing is the gasket is new around 2k miles....it idles up and down also to 300 to 600 and stays at 300 its kinda low idle.. and i know i need to time it up dont have tools this is like my 3rd swap on a car and i wanna figure it out my self but need help
Old Jul 20, 2010 | 07:02 AM
mouab18c1's Avatar
Do you hear any vacuum leaks?
Old Jul 20, 2010 | 08:17 AM
efnoobie's Avatar
yea the one on the front of the intake manifold..
efnoobie's Avatar
but plugd it
Old Jul 20, 2010 | 06:07 PM
EHondaJDM's Avatar
fix the idle
4drsedaneg
Welding / Fabrication
May 27, 2008 06:36 AM
hcivic99
Jun 8, 2005 06:34 PM
jdmtuner64
Jan 19, 2005 09:09 AM
