Battery Recommendation
Old Jul 14, 2001 | 07:40 PM
voidwarranty's Avatar
Default Battery Recommendation
Does anyone have a battery they recommend??
Old Jul 14, 2001 | 10:58 PM
George H's Avatar
Default Re: Battery Recommendation (voidwarranty)
I was in the same position as you and I thought that the Diehard battery was the best. It turned out though that it wasnt that good from the people I asked. So I bought the Duralast, which I must say, is probably the best standard battery you can buy. It won several awards and to top that all off its original equipment on all Hummers
Old Jul 15, 2001 | 12:20 PM
Rain_man's Avatar
New User
Default Re: Battery Recommendation (KANJI)
I like AC Delco, just cause Honda includes it in some of their cars and because it was rated best battery a couple of years ago.
Old Jul 15, 2001 | 01:02 PM
acuraintegraman's Avatar
Default Re: Battery Recommendation (Ein)
i had an ac delco and it did it's job. if you don't have a massive system then any battery will most likely get the job done. if you have money to spend, then i would recommend a reactor power cell battery. you can order one from summit and it's lighter than the stock battery, fits in the stock location, and delivers over 800cca. i'm using one and no complaints
Old Jul 15, 2001 | 02:56 PM
leechungsr's Avatar
Default Re: Battery Recommendation (Teken)
Yup, I was about to rcommend the Optima. It's supposed to be the BEST there is. It's a bit pricey, but if you plan on keeping your car for a long long time, get it. Comes with a lifetime warranty
Old Jul 15, 2001 | 03:16 PM
Default Re: Battery Recommendation (owkone)
does the yellow top optima fit in an integra? i looked into one of those, don't remember which color and it did not fit
Old Jul 15, 2001 | 03:23 PM
dc24me's Avatar
SVR12-50, I think. It's designed for 92 and up civics (and Integras) and drops right in. It's a gel type deep cycle battery which can also hold more current. It's definitely has more cold cranking amps than the stock battery. Even when if you con't have a large current sucking audiosystem or extra lights or HIDs, the car will probably turn over during the winter (if it's cold where you live). Not if mention you accidentially left your dome light for a couple of days, your alarm would probably still work. They go for like$139 or so.
Old Jul 15, 2001 | 03:26 PM
dc24me's Avatar
Default Re: Battery Recommendation (dc24me)
The Optima Yellow Tops will not drop right in. They're huge and would require some triming of the casing. I'm 99.8% sure, but someone correct me if I'm wrong....
Old Jul 15, 2001 | 03:48 PM
X2BOARD's Avatar
The optima yellow is the one that I am looking into as well... from my research, it is the best battery out there, price not being a consideration. My car has alot of electronics and lights to run and this is the one I am going for, as soon as I get back from vacation... I'd be interested to know if they fit in the teg w/o modification !
Old Jul 15, 2001 | 04:36 PM
KL's Avatar
KL
New User
My stock Acura battery on the 1996 GSR is still going strong, the car is 5 years old now, used pretty much every day, I am curious when it will die on me.
The Canadian Tire (local automotive supply chain store) batteries I bought before usually only last a couple of years.
I am inclined to stay with Acura battery myself as it has two full years of exchange (ie not pro-rated) warranty.
Old Jul 15, 2001 | 04:42 PM
slowerthanu's Avatar
New User
Default Re: Battery Recommendation (KL)
I have an optima yellow top in my Integra and I love it. There is an ultralight battery out there but the name slips my mind
Old Jul 15, 2001 | 04:46 PM
Rain_man's Avatar
New User
Hey Teken, do you mean marine or military spec... You just mainly are trying to suggest deep discharge spiral batteries right?
Old Jul 15, 2001 | 06:01 PM
So will the red top Optima battery fit in a G3 teg? is it deep cycle?
Old Jul 15, 2001 | 06:45 PM
leechungsr's Avatar
Whatever battery you buy check out the ColdCranking Amps get the largest CCA you can get.
Some manufacturers over rate their CCA...so, a good way to compare is by the weight. If the battery is super heavy and beefier than another with the same CCA..you know the heavier one is better.
Old Jul 30, 2001 | 08:13 PM
JinMTVT's Avatar
New User
Default Re: Battery Recommendation (LeeChun GSR)
and when u wanna loose weight with new battery ?
is there any good racing battery brands ?
could it be used for street ??
Old Jul 30, 2001 | 08:32 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Battery Recommendation (JinMTVT)
how about a quick one that would clarify things for everyone...
does anyone know of a yellow top or red top battery, or equivalent, that will drop in a G3 integra? Does anyone with a G3 integra have a kick *** battery that they would brag about? I haven't had any problems with my acura battery yet, but there is nothing sexy and gleaming about the oem battery when you pop your hood.
thanks
Old Jul 30, 2001 | 08:56 PM
New User
yea... don't think i want something that heavy... thanks for the info though!
Old Jul 30, 2001 | 09:24 PM
The Mick's Avatar
Default Re: Battery Recommendation (Pb_Foot)
...there is nothing sexy and gleaming about the oem battery when you pop your hood.
Mine is... well, it's gleaming anyway.
Check it out:
http://albums.photopoint.com/j/ViewP...p=21236369&f=0
D'oh! (8(O) Photopoint!
[Modified by The Mick, 10:26 PM 7/30/2001]
[Modified by The Mick, 10:29 PM 7/30/2001]
Old Jul 30, 2001 | 09:37 PM
Rain_man's Avatar
New User
Default Re: Battery Recommendation (The Mick)
The main reason why you would want one of those batteries is if you have a stereo system that warrants such a battery.
And if you have that nice of a system, you aren't worried about weight as it is, so a heavy battery won't matter.
Old Jul 30, 2001 | 10:40 PM
Doesnt matter now.....My 97GSR is the size of a CRX....
Old Aug 1, 2001 | 06:19 PM
Integ90's Avatar
Red top Optima. been in my car for almost 7 years. Running an ignition amp and 2 stereo amps.
wrx-killer-Sti-eater
Audio / Security / Video
60
Feb 19, 2013 07:42 PM
kasimmmmm
Dec 5, 2007 05:47 PM
JMD
Dec 29, 2004 04:19 PM
BlackThorN
15
Jun 27, 2004 01:31 PM
DRKSol
Jun 10, 2003 06:44 AM
