Suspension install help.
Old Jul 15, 2001 | 03:12 PM
dc24me's Avatar
Default Suspension install help.
I've had a set of Neuspeed Sport Springs and when I had them installed on the stock shocks, the factory bump stops were cut. What do I do now when I put on my KYB AGXs? I can't remember if the reason they were cut was because I was using the stocks...
Old Jul 15, 2001 | 09:26 PM
SlipAngleX's Avatar
Default Re: Suspension install help. (dc24me)
Didnt totally get the drift of your question but,
you'll have to cut 1/2 of the stock bumpstop and use the upper half (the thicker one)
So, if it was already cut, you should have 2 lumps, that kinda look like a pyramid!?!
To avoid shock damage, don't go more than 1/2 the size of the original bumpstop
Old Jul 16, 2001 | 04:09 AM
Asahi's Avatar
Default Re: Suspension install help. (4DoorTeg)
Your bumpstops are fine just reuse them.
Old Jul 16, 2001 | 04:54 PM
2001RED's Avatar
New User
Default Re: Suspension install help. (Jay D Em)
Uh...If you install anytype of aftermarket lowering springs, you'll have to cut the bumpstops according to the instructions they provide or else you'll have a bump *** ride. As far as I know, Eibach, Intrax, H&R(same as neuspeed), all require you cut the bumpstop according to most imports.
Old Jul 16, 2001 | 08:43 PM
dc24me's Avatar
I DON'T remember exactly what it said in the instructions. They were originally installed 2 years ago and I had a shop do them for me. I thought aftermarket shocks in general have shorter bodies because they already take into account the user is probably using shorter springs.... but then again, I could be wrong.
themilman
Suspension & Brakes
May 28, 2007 08:55 PM
low430
Sep 25, 2005 12:58 PM
EeeJayEight
Jul 19, 2004 09:43 AM
EVIL Hx Coupe
Sep 3, 2002 12:30 PM
syrinx
Aug 15, 2002 01:12 PM
