Which wire off the ECU is for VTEC?
Old Jul 16, 2001 | 09:16 AM
5 Liter Eater's Avatar
Default Which wire off the ECU is for VTEC?
I hooked up my A/F and boost gauges and also decided to put in a VTEC light while I was at it. I thought it was pinout A4 but this might be the VTM wire. Anyway, it's not working. My Helms is just for a '94 Integra, not a GSR so it has no mention of the VTEC signal wire.
Anyone know the correct wire?
Old Jul 16, 2001 | 09:17 AM
eg6ajk's Avatar
Default Re: Which wire off the ECU is for VTEC? (5 Liter Eater)
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
hope this helps
Old Jul 16, 2001 | 09:20 AM
Default Re: Which wire off the ECU is for VTEC? (eg6ajk)
Kinda. Since I already have it connected to A4, which is green/yellow as I remember, I guess I need to check the continuity to the LED and if that checks out, check out why I am not going into VTEC....That will be fun.
Old Jul 16, 2001 | 09:47 AM
G3-GSR's Avatar
New User
are you having a problem going into VTEC or having a problem with your VTEC LED?
Old Jul 16, 2001 | 09:57 AM
Default Re: Which wire off the ECU is for VTEC? (G3-GSR)
The light isn't coming on and I can't really tell if the VTEC is kicking in or not so I'm not really sure. The secondary runners are definitely working but I donno about the VTEC.
h22killer
Engine Management and Tuning
Oct 1, 2011 04:57 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
jetoutant
11
Jan 2, 2008 07:50 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
