Dyno tuning procedure
Old Jul 19, 2001 | 05:17 PM
darrona's Avatar
New User
Default Dyno tuning procedure
I will be taking my car (94 GSR) to a dyno on Saturday, which doesn't really have too much experience w/ imports... So I was wondering what procedure I should use for tuning. I have CTR intake cam, DC 4-1 header, CAI, AEM cam gears, and a Field VTEC controller. Should I find optimum vtec crossover point first, then cam timing, then make fuel adjustments??? What are some good starting points? Any help will be greatly appreciated!
Thanks,
Dave A>
Old Jul 19, 2001 | 05:19 PM
non-VTEC's Avatar
Default Re: Dyno tuning procedure (darrona)
i think cam timing first. also adjust ignition timing once you move the intake cam gear. then maybe your VTEC x-over point and then fuel tuning.......
Old Jul 20, 2001 | 06:27 AM
Go Mifune's Avatar
New User
http://www.hondata.com/tech.html
check out:
* Tuning guide
* Using a dyno
* Tuning cam timing
The following is recommended before starting to tune an engine:
* Set the cam timing. (i think they mean to Ø)
* Set the ignition timing.(to stock)
* Check the fuel pressure under load.
Tuning the engine
The normal approach is to:
* Tune the mixture.
* Tune the ignition timing.
* Tune the cam timing.
This process may be repeated if a large change is made tuning one area.
kikeh22
13
Sep 29, 2004 05:00 AM
b00stedbyFastrax
May 22, 2003 08:52 AM
importadrenelin
Aug 21, 2002 02:29 PM
kefka
Apr 15, 2002 07:42 PM
