ls/vtec
Old Jul 16, 2001 | 10:19 PM
Integra187's Avatar
Default ls/vtec
i heard that ls/vtec will allow you to run low 14's. What do u actually need for the conversion and how much does it cost around. Also will ls/vtec cause any problems for the engine?
Old Jul 16, 2001 | 10:55 PM
13secLSVTEC's Avatar
New User
Default Re: ls/vtec (Integra187)
A LS/VTEC that is done right will not cause any engine problems. If you do all the labor yourself, it can be done for around $1200 or so. There is a pretty long list of things needed...here's the majority of them...
VTEC Head, ECU, Oil pump, Water pump, Distributor
LS Head gasket, timing belt
Oil Line fittings
It is also wise to swap out pistons, since the motor will be out anyway.
CTR or JDM B16 SiRII pistons are well worth the money...
Put it all together and you now have a 13 or 14 sec LS
LSVTECJW
Aug 16, 2007 09:00 PM
Toy Civic
Mar 3, 2007 11:31 PM
MugenB16A2
11
Jan 30, 2005 09:15 PM
jedi27sith
Jun 11, 2003 02:34 PM
Honda_HatchEG
Dec 5, 2001 10:33 AM
