Zex install help
Old Jul 23, 2001 | 02:31 PM
zojirushi's Avatar
Default Zex install help
Is it safe to run the nos through your car like a amp wire? A friend of mine told me its actually better and safer than running it underneath your car.
Old Jul 23, 2001 | 03:01 PM
Phat Corolla's Avatar
New User
Default Re: Zex install help (zojirushi)
gosh, I think running NOS thru the inside of my car would scare me. Unfortunately, i don't have a good answer for you though.
Old Jul 23, 2001 | 07:21 PM
TypeC's Avatar
Default Re: Zex install help (Phat GS-R)
NO!!! Don't do it. I have the ZEX kit and let me tell you, it's acutally EASIER to run it outside of the car. All you have to do is drill a small hole underneath the rear seat and run the lines (using zip ties) along the frame (I used the brake line rail) and to your motor. Much easier than pulling carpet/consoles and going through the firewall. The main reason is that if it leaks, you won't die/pass out. It is NEVER a good Idea to run fluids in the inside of your car (gas, oil, Nitrous). HTH, -C
Old Jul 24, 2001 | 04:45 AM
GSRacer's Avatar
New User
Default Re: Zex install help (TypeC)
yeah, he's right. it's actually easier underneath the car.
Old Jul 24, 2001 | 11:21 AM
zojirushi's Avatar
Default Re: Zex install help (GSRacer)
damn, i read the replys a little too late. I already ran the line through my car
Really wasn't that hard. Took us about 20 mins to run the line. I hope i don't die
[Modified by zojirushi, 3:21 PM 7/24/2001]
[Modified by zojirushi, 3:22 PM 7/24/2001]
Old Jul 24, 2001 | 01:35 PM
myNAteq's Avatar
New User
[quote]damn, i read the replys a little too late. I already ran the line through my car
[quote/]
Was the kit easy to install, I'm getting mine this week. Are the direcitons clear? What's the hardest part?
thanks
[Modified by myNAteq, 10:37 PM 7/24/2001]
Old Jul 24, 2001 | 01:56 PM
Scotty's Avatar
Default Re: Zex install help (myNAteq)
Actually the only person that will be laughing - IS HIM!
Old Jul 24, 2001 | 01:58 PM
Scotty's Avatar
SHouldn't you have waited for responses? Isn't that the point of leaving a thread?
Anyway! REDO it man.
Old Jul 24, 2001 | 02:16 PM
zojirushi's Avatar
actually the kit was fairly easy to install as soon as you figure out where to put things. the intructions that come with the zex kit i think is stupid. Try to get someone who has experience with the installation to help you out.
Old Jul 25, 2001 | 05:56 AM
TypeC's Avatar
yeah, definately Redo the line. It'll only take 20 mins and will save your life. Plus when I remove my line (when I take it to the dealer), it only takes me 5 mins to remove.
The directions are ok, but the pictures SUCK. I just had to figure out what bit goes where on my own. They should show pics that aren't zoomed in so far. HTH, -C
teg969
Mar 5, 2007 04:38 PM
NitrousB.I.G.
Mar 20, 2006 08:33 PM
milton
May 9, 2004 11:07 AM
97GSRTeg
May 9, 2002 06:09 PM
-=TWITCH=-
Apr 26, 2002 08:50 AM
