high hc's. need help
Old Jul 19, 2001 | 09:25 PM
blaze's Avatar
Default high hc's. need help
i just recently tried to pass my car for registration at a state ref and i had high hydrocarbons(sp)? any of you smog pros out there know how i can lower my hc's??? b18c1 in a cx, btw....
Old Jul 19, 2001 | 09:59 PM
Ricehornet's Avatar
Default Re: high hc's. need help (blaze)
is that it? a b18c1 in a crx? everything else is stock?
Old Jul 19, 2001 | 10:02 PM
blaze's Avatar
Default Re: high hc's. need help (Ricehornet)
yup. b18c1 in a CX. all stock, all wired, no codes, all smog devices hooked up. passed visual. just high hc level...
Old Jul 20, 2001 | 05:39 AM
blaze's Avatar
anyone???
Old Jul 20, 2001 | 05:51 AM
b18b98's Avatar
Was your car really warmed up when you went to get it inspected?? You usually have to beat on it really hard to get the cat really hot to do its magic...or you can get that stuff at pep boys that guarantees to pass emissions...i don't know what its called but if you ask one of the sales people they'll show it to you...good luck
Old Jul 20, 2001 | 09:43 AM
D-SPEED's Avatar
Default Re: high hc's. need help (b18b98)
i had the same problem just last month......ive got a 94 gsr with I/H/E.....passed visual but i was getting really high HCs. Try doing these things:
-new plugs
-new cap and rotor
-new wires if they are old
-if you have stock intake/headers that will help too
-valve adjustment will help too
-if you have a friend to swap cats with, that can help ( if yours is old)
-sometimes a bad o2 sensor can give you high HCs ( those are pretty expensive to replace though.....like 150-200 bucks)
-a cheap cat can be had for about 70 bucks
Old Jul 20, 2001 | 10:13 AM
berkel's Avatar
Default Re: high hc's. need help (D-SPEED)
Hi,
I would def run the **** outta the car, get it nice and hot. Try not to sit there idling too long in line, heh.
Try the fuel stuff.
I was able to pass with mine, but just barely on the HC. My mechanic said he was leaning it like 40% with VAFC, hehe. That would def help if you could get one.
FB
Old Jul 20, 2001 | 10:55 AM
blaze's Avatar
Default Re: high hc's. need help (berkel)
thanks for the help guys. i picked up a new cap, rotor, and plug wires. i already had installed new spark plugs and a brand new o2 a couple days before... i'll try the suggestions....
thanks again, my appointment is on monday at evergreen college here in the bay
hopefully i pass this time...
Old Jul 20, 2001 | 05:49 PM
non-VTEC's Avatar
high HC at idle or on the driving test?
either way you gotta make sure the converter is smoking hot! i mean beat on it until you get to the smog check place!
also try retarding the timing a little.........that will help.
theslugbug
Sep 29, 2009 11:01 PM
desiromeo812
Oct 2, 2008 10:00 PM
Edulerp
Jul 15, 2006 02:48 PM
underb00steg6
Nov 14, 2004 07:45 PM
blaze
Jul 20, 2001 10:51 AM
