problem with ground control coilovers
Old Jul 19, 2001 | 11:44 PM
keys's Avatar
Default problem with ground control coilovers
hey guys, i have the older version of the ground control coilovers that look like this:
notice there's a gold adjuster and the locknut in the middle that locks the adjuster in place.... well, on both of my rear GC coilovers this locknut is stuck in place..... my guess is it's from rust and dirt and that kinda stuff...... anyone have any suggestions on how i may be able to loosen this locknut? i've only been trying with a small allen wrench... do you recommend i try and use a socket wrench with an allen attachment and just try to turn it really hard? i'm afraid that little locknut will break... TIA
Old Jul 20, 2001 | 12:22 AM
ingrate's Avatar
25 Year Member
Default Re: problem with ground control coilovers (keys)
Don't force it, that small screw is weak. Try lubing it up with some WD-40 for a bit
Old Jul 20, 2001 | 07:13 AM
Ubermensch's Avatar
Default Re: problem with ground control coilovers (In7egrity)
Penetrating oil and give it a couple of knocks to set up a vibration. let it sit, then give it another try.
Old Jul 21, 2001 | 01:08 AM
keys's Avatar
Default Re: problem with ground control coilovers (Ubermensch)
alright, i'm gonna try that.... but if that doesn't work, do you think I should just buy the newer version of the GC coilovers? the newer version has a locknut that makes the gold adjuster hug the coil instead of jam a nut into the threads
Old Jul 21, 2001 | 08:31 AM
PROFILES2000's Avatar
yah lube it up with something hopefully everything works out........i try to clean mine abut once a month
HatchbackSiVtec
20
Mar 18, 2003 09:09 PM
[HrZn]4life
Jan 14, 2003 09:01 AM
crexer
Nov 5, 2002 08:23 AM
djay86
Jul 31, 2002 08:06 AM
AllMotorITR
Dec 13, 2001 06:37 PM
