ECU Pin Layout
Old Jul 21, 2001 | 07:19 AM
Primo's Avatar
New User
Default ECU Pin Layout
can someone send me a link for the ecu pin layout for a p-72? Or can you tell me what locations for the o2 sensor? Need to get rid of check light.....Thanks
Old Jul 21, 2001 | 07:42 AM
HX_Guy's Avatar
Default Re: ECU Pin Layout (Primo)
Here ya go:
The O2 sensor pins are in section A number 5 and 6.
#5 is the Secondary O2 Sensor Heater Control (SO2S HTC).
#6 is the Primary 02 Sensor Heater Control (PO2S HTC)
And also in section D number 7 and 14.
#7 is the signal for the Primary Heated O2 Sensor (PHO2S)
#14 is the signal for the Secondary Heated O2 Sensor (SHO2S)
[Modified by HX_Guy, 9:15 AM 7/21/2001]
Old Jul 21, 2001 | 07:47 AM
HX_Guy's Avatar
Default Re: ECU Pin Layout (HX_Guy)
Damn...you better have meant OBDII 96-98 P-72..or I mgonna be pissed cause I spent all that time researching!
Old Jul 21, 2001 | 07:53 AM
Primo's Avatar
New User
thanks man but it is obd 1...........sorry should have been clearer! Help me out again if you can.....appreciate your time
Old Jul 21, 2001 | 08:02 AM
HX_Guy's Avatar
Damn..should have known...let me see what I can find...
Old Jul 21, 2001 | 08:13 AM
HX_Guy's Avatar
Ok..heres the OBDI ECU plug:
A6 is the O2S HTC (heater control) - wire will be orange/black
D14 is the O2S signal - wire will be white/red
Old Jul 21, 2001 | 10:54 AM
Flamenco-T's Avatar
so another words, on OBD II
the A5 is the same as D14
then the A6 is the same as D7 ?
so I can tap in in either one of those to get an O2 signal right ???
BTW, which is the VTEC solenoid wire on the OBD II, is it A8 ?
thanks
Old Jul 21, 2001 | 11:25 AM
HX_Guy's Avatar
Default Re: ECU Pin Layout (flamenco)
No the yare not teh same. D7 and D14 are signal pinouts.
A5 and A14 are heater controls...you wont get a signal for that.
If you are trying to hook up an air/fuel ratio gauge...you tap into D7 on OBDII ECUs.
A7 is the VTEC pinout.
Old Jul 21, 2001 | 02:43 PM
Flamenco-T's Avatar
you mean A8 ?
thanks
Old Jul 21, 2001 | 04:00 PM
HX_Guy's Avatar
oops..yes A8
sampson100
Dec 10, 2010 08:12 AM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
rice4life
Jun 26, 2003 03:39 PM
creuger
Nov 15, 2002 07:11 PM
