PLEASE HELP CAR KEEPS STALLING!
Old Jul 27, 2001 | 10:13 PM
akatoffeeboy's Avatar
New User
Default PLEASE HELP CAR KEEPS STALLING!
IV'E JUST RECENTLY PUCHASED A 92 INTEGRA AND I AM HAVING DIFFICULTY WITH IT ALREADY..........THE PROBLEM IS THAT SOMETIMES MY CAR WILL NOT START.IT WILL GET TO THE SECOND PHASE OF IGNITION I.E ALL THE ENGINE LIGHTS COME ON AS NORMAL AND WILL CRANK IN THE THIRD PHASE....HOWEVER THE CAR DOES NOT START UNTIL NUMEROUS TRIES.ALSO ON OCCASIONS I WILL BE DRIVING DOWN THE ROAD AND MY CAR JUST SHUT DOWN (STALLS) AND THERE SEEMS TO BE NO POWER(THE ENGINE LIGHTS ON THE DASHBOARD GO OUT) AND AGAIN I MUST CRANK SEVERAL TIMES BEFORE I HAVE ANY SUCCESS.IF YOU CAN HELP PLEASE EMAIL ME AT akatoffeeboy@hotmail.com
Old Jul 31, 2001 | 04:38 AM
IgniteTeg's Avatar
Default Re: PLEASE HELP CAR KEEPS STALLING! (akatoffeeboy)
IMO it seems like your alternator is bad not chargin back the battery. Or your starter is bad also. You gotta get these check and found out. Good luck. I'd say its your alternator since you say power is out and stuff and makin it harder to start the ignition also check your battery. Good luck thats my 2¢
[Modified by Vietracer, 5:45 AM 7/31/2001]
Old Jul 31, 2001 | 06:18 AM
nerdish's Avatar
Default Re: PLEASE HELP CAR KEEPS STALLING! (Vietracer)
Try simple stuff first, like make sure the terminals on your battery and nice and clean. Take a heavy duty brush or something to that beotch.
Old Jul 31, 2001 | 06:33 AM
WOTTEG's Avatar
Take the battery to your auto-parts store and have them check it. Wonder if you have a loose electrical connection for timing or fuel. . . . .
Old Jul 31, 2001 | 07:11 AM
stick's Avatar
Default Re: PLEASE HELP CAR KEEPS STALLING! (WOTTEG)
yeah any local auto store should be able to check ur battery and alt to see if its shot. the starter has to be off the car i think
but sounds like ur alt tho
Old Jul 31, 2001 | 07:20 AM
nutsack's Avatar
sounds like you need a new battery.
bamaTeg's Avatar
New User
Default Re: PLEASE HELP CAR KEEPS STALLING! (stick)
most likely it is your ignitor. My civic had a recall on it and I didn't take it in until I had the same symptoms. Also, there was another guy on the board with a g2 teg that had the same problems. As far as the battery goes, I've heard once you start your car you can disconnect the battery and the car still runs since that's what the alternator is for so the car going dead doesn't sound like the battery. My money is on the ignitor. Good luck!
Old Jul 31, 2001 | 09:05 AM
Dave421's Avatar
Default Re: PLEASE HELP CAR KEEPS STALLING! (bamaTeg)
You say you just bought the car? Well, maybe it's just me but...Have you gotten gas recently? Have you noticed any correspondence between filling up and when the problem started. you may have simply gotten a bad tank of gas. Try filling up (or adding octane booster) to see if that helps. Also, one other thing that causes that problem (anyone else had this problem) could be your turn signal/headlight stalk. Mine went out and I went all through the car before taking it to my mechanic. 15 min. later he tells me it's the turn signal stalk! It had a short and it was causing the car to freak out. (I swear, I'm not high...)
Anyway, those are 2 other possibilities.
Old Jul 31, 2001 | 12:10 PM
Mr. Choi's Avatar
New User
well guy here is your problem...
YOU BOUGHT THE CAR, A PIECE OF $HIT CAR...
ok anyways, its not the battery or the alternator, why? because if you can crank the engine after it stalls then it means the battery still has power. if the engine died cause the battery or alternator was bad, then he could not have cranked to try starting the car again, duh
dont even bother with the battery or alternator.
what bamateg and dave421 said could be your problem, about the igniter and or having a short in the electricals somewhere. im not sure where else could be the problem but those are a good place to check. actully jus take it to a shop since it sounds likeyou dont know much about cars, sorry to say but it might be true. jus taking your car in somewhere get it check outsee whats wrong and bust out your wallet or your parents wallet and pay the mechanic to fix it. you first should had the car check out by a mechanic before you bought it. big mistake
Old Aug 1, 2001 | 06:14 PM
Integ90's Avatar
Default Re: PLEASE HELP CAR KEEPS STALLING! (Chois i-VTEC)
Check the igniton switch. I had the same problem, the mechanic took apart my steering wheel and showed me that the wires inside got fried. $40
staneg90710
Oct 11, 2018 08:25 AM
patrickstar
12
Jan 12, 2009 05:22 PM
trianglegreg
May 15, 2008 12:23 PM
AzntstyleZ
10
Feb 27, 2004 10:50 PM
stickshift
Jul 17, 2003 06:57 PM
