Headlight aiming...clockwise=up or down??
Old Jul 21, 2002 | 09:29 PM
ebelp's Avatar
Default Headlight aiming...clockwise=up or down??
I found out the to aim the driver's side lowbeam headlight up, you have to turn the screwdriver clockwise. Is this the same for the passenger side? It seems like you would have to spin the gear the opposite way on the other side.....
Old Jul 21, 2002 | 09:32 PM
o_Rage_o's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (ebelp)
Counterclockwise is down I belive, just check the level, if the bubble is going towards the cabin the headlights are getting higher...
-Rage
Old Jul 21, 2002 | 09:34 PM
ebelp's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (o_Rage_o)
Good point....my HID's are waaay too low. I won't be happy until I'm blinding people....hehe...
Old Jul 21, 2002 | 09:56 PM
jeebusm3's Avatar
not tryin to be a smart *** but, just look at the light, is it goin up or down?
Old Jul 22, 2002 | 06:13 PM
ebelp's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (gtravsr)
It's not as easy as it looks, you can spin the little "gear wheel" forever, and the lighy won't seem to move at all...it takes a while to do, and I don't want to spend 10 min. turning the thing one way, and then find out I was spinning it the wrong way the whole time...
Old Jul 22, 2002 | 06:33 PM
98R-1144's Avatar
i agree. i always remind myself to remember which way does what..but i always forget.
i too would like to know if Clockwise = Up or down... and is that on both sides?
Also, for horizontal movement, is Clockwise Left or Right... and is that on both sides?
shoot, you can even wonder if it's the same for JDM headlights..or are they reversed?
Old Jul 22, 2002 | 09:12 PM
avs's Avatar
avs
If it's off by a whole lot. You might need to take out the headlight assembly and bent the tab. It's a pain in the ***. You have to take out the whole bumper cover off to do that. Good luck.
Old Jul 23, 2002 | 10:24 AM
ILUVTEC's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (avs)
Here's the info:
Clockwise is up, and this is for both sides.
CCW is down, for both sides as wel.
Enjoy
Old Jul 23, 2002 | 12:55 PM
shattergsr's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (ILUVTEC)
Here's the info:
Enjoy
tnx for the info, I remember the last time I was adjusting it I was turning it the wrong way for 15 minutes, my hand was so sore and then I looked at the gauge and the bubble went the wrong way!
Old Jul 23, 2002 | 02:50 PM
non-VTEC's Avatar
so turing that stupid plastic allen bolt thingy accually adjusts the headlight aim? i was turning that damn thing for a long damn time and it seemed like it never moves........
is there a limit as to how much you can accually turn it? maybe i can finally adjust them to how i want........
Old Jul 24, 2002 | 11:09 AM
snkypete's Avatar
New User
Default Re: Headlight aiming...clockwise=up or down?? (non-VTEC)
i had the same problem today.. so i searched and found this post.. damn, now my hand hurts from all this turning
Old Jul 29, 2002 | 06:20 PM
ebelp's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (huk)
Sweet, clockwise is up on both sides....let the games begin. And by the way, if the bubble moves towards the cabin, your beam is going down...
[Modified by ebelp, 3:20 AM 7/30/2002]
Old Jul 29, 2002 | 06:35 PM
IgniteTeg's Avatar
yeah spinnin that takes forever just to see some kinda of adjustin on the headlight beam
Old Jul 29, 2002 | 07:07 PM
RC211V's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (IgniteTeg)
do you guys aim lower or higher? i kinda wanna aim mine up at those damn SUV that tail gate us and blind us with there low beams but they look like high beams. dont you hate that?
Old Jul 29, 2002 | 07:13 PM
IgniteTeg's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (JDMintegGSR)
Mine is a little higher to even out and yes It always get on my nerves to see those suv and big trucks behind me.
Old Jul 29, 2002 | 08:25 PM
sleeepy's Avatar
do u guys have pics of where they located? thanks
Old Jul 30, 2002 | 01:56 PM
ebelp's Avatar
Default Re: Headlight aiming...clockwise=up or down?? (sleeepy)
I don't have any pics, but there are really good pics in your owners manual.
Old Aug 12, 2002 | 05:33 AM
2000GSR's Avatar
when my headlights are level(bubble in middle on 0) the headlights still seem to be pointing down!! when i adjust my headlights, a week later and they need adjusting again!! does anyone else have this problem??
Old Aug 12, 2002 | 06:47 AM
Ricky Rojales's Avatar
Helms for GSR:
Distance from a white screen (use a flat wall in your garage or mock up a wall using a white sheet hanging from a string stretched across, use weights/bricks at the bottom of the sheet to anchor the sheet and flatten the target surface) from headlamp to screen: 9 ft. 10 in.
Distance from headlamp to ground: 23 in. (I could be mistaken... I'm going by memory)
Note: If your car's lowered 2 inches then subtract this difference from the OEM height spec. Thus, 23 - 2 = 21 inches.
It should look like this on the screen: ____,----~=____,----~==
If you start lighting up street signs then your headlights are TOO HIGH! Lower it a little by an inch and work from there. Your driver's side headlamp has more to do with this.
HTH
[Modified by Fluoxetine HCL, 10:53 AM 8/12/2002]
LatinoHeat
Honda Civic (2001 - 2005)
Sep 3, 2014 12:30 PM
foxfai
Jan 4, 2008 07:48 AM
boosted k20
Jun 19, 2005 07:41 AM
Sohc Driver
Jan 3, 2003 10:41 PM
