Trans question again...
Old Jul 19, 2002 | 08:38 AM
Arsenal's Avatar
Default Trans question again...
I am still in the process of doing the 3rd gear sync, I know for sure that it is an LS trans but I am not sure about the gears. Acura are charging 300 for the gear and sync. But can you for example have GSR 1 and 2 gear, then an LS 3 gear, or LS first and second, then LS third. If anyone knows the sooner the better as i am now changing gear at 1200rpm.
Thanks
Old Jul 19, 2002 | 08:40 AM
Arsenal's Avatar
Default Re: Trans question again... (Arsenal)
I meant LS first and second, then GSR third sorry.
Old Jul 19, 2002 | 11:40 AM
TEG98's Avatar
The gears are interchangable, I have a friend with a crx european spec close ratios but has a (us) civic 5th so that he can get good gas mileage.
It can be done.
Old Jul 20, 2002 | 10:32 AM
Arsenal's Avatar
Default Re: Trans question again... (TEG98)
I found out that they are LS gears, but is it worth putting a GSR third gear into the mix?
jetspeedz
Nov 6, 2010 03:55 PM
turbo-crx
Aug 6, 2009 09:08 AM
tegasaurus
Dec 14, 2003 08:11 PM
Toda Party
Sep 18, 2003 09:17 AM
