help with brakes quick!!!!!!!
Old Jul 21, 2002 | 02:50 PM
2LoW4FaThOeS's Avatar
Default help with brakes quick!!!!!!!
my abs has been disconnected (fuses removed because the pump went) for some time now, well to free up more space in my engine bay i tried removing the whole unit. my dumb friend told me it was alright to cut the wires and well lets just say I HAVE NO BRAKES NOW. fluid just shoots out the lines where they were cut. what should i do? what is the cheapest way. please post or AIM me at SLOWnLOW95 asap cause we are trying to figure out what the fuc* we messed up. thanks tommy
http://www.imagestation.com/mypictures/inbox/ link might not work sorry
[Modified by 2LoW4FaThOeS, 12:00 AM 7/22/2002]
Old Jul 21, 2002 | 05:32 PM
Tweakmeister's Avatar
Default Re: help with brakes quick!!!!!!! (2LoW4FaThOeS)
rofl, sorry dude
you could try to seal the cut lines, but you best bet is new stuff...
Old Jul 21, 2002 | 05:43 PM
ingrate's Avatar
25 Year Member
Default Re: help with brakes quick!!!!!!! (Tweakmeister)
did you cut your brake lines? try asking someone with SS lines for their stock ones
Old Jul 22, 2002 | 03:28 PM
i'm dumb what can i tell you.
well i called acura they want $163 just for those wires.
but they recommended that since the ABS unit isnt working anyways and its only used as a bypass that, i should change the brake system over to the RS style with a proportionings valve instead and use those wires which comes out to about $158 for the vavle and buy RS wires which comes out to about $158 for the valve and about 100 for the brake lines.
but my idea was the proportioning valve and getting the goodridge stainless stell brake lines instead of the stocks for $30+ more. but do the stainless steels actually run all the way from the unit? I should purchase the wires for a RS which uses the porportioning valve right?
THANKS AGAIN TOMMY
Old Jul 22, 2002 | 03:31 PM
just relized that the stainless steel lines don't run from the unit itself so looks like ill be purchasing the stock ones after all.
FIBAH
Feb 25, 2017 05:53 PM
champ52204
Feb 16, 2008 09:20 PM
EJ7_1998
44
Jun 11, 2007 06:33 AM
maxboost_50psi
Feb 11, 2007 04:37 AM
IGGY
Mar 3, 2003 07:48 PM
