does anyone know what a tdc sensor does?
Old Jul 20, 2002 | 09:16 PM
wickedxboi's Avatar
Default does anyone know what a tdc sensor does?
im throwing up the tdc sensor code? does anyone know how to fix it or what to look for?
Old Jul 20, 2002 | 11:19 PM
MikeSarr_GSR's Avatar
Default Re: does anyone know what a tdc sensor does? (wickedxboi)
it refrences to the ECU when the engine hits TDC in the cylinders.
it then uses that to send the spark timing. I know it does more...
Old Jul 21, 2002 | 12:29 AM
GZR4DR's Avatar
Default Re: does anyone know what a tdc sensor does? (MikeSarr_GSR)
TDC stands for top dead center. You set everything to TDC when replacing a timing belt or installing new cams/gears. If you don't your car will not function properly. Grab a helms, look for the code and name. Then find the sensor location off the helms and replace if necessary.
Old Jul 21, 2002 | 08:37 PM
wickedxboi's Avatar
Default Re: does anyone know what a tdc sensor does? (GZR4DR)
ok..thanks guys
Old Oct 28, 2003 | 06:30 PM
michaelpr's Avatar
New User
Did you have to replace the distributor? If so, did it resolve your problem?
Old Oct 28, 2003 | 08:12 PM
chamoru's Avatar
I was getting the same code, I replaced my distributor and reset the ecu and no more codes.
m3kid
Jun 2, 2012 11:47 AM
Anti-Drama Queens
Apr 11, 2006 03:58 PM
snatch
Dec 13, 2004 04:28 PM
SpoolinEK
12
Jun 18, 2002 05:32 AM
