DA or EF radiator
Old May 4, 2004 | 07:50 PM
iwhichisme's Avatar
Default DA or EF radiator
I have a 90 teg, and am looking for a radiator for it. My freind has a rediator from a 91 civic si. They look pretty similar but its hard to tell in the car. My question is, can i use this radiator on my car, or are they too much different?
peace,
Old May 4, 2004 | 07:53 PM
andrew dc's Avatar
Default Re: DA or EF radiator (iwhichisme)
you can probably use it, but most ef civic radiators are 2/3 length and single core... since they are d series, single cam. The DA being dual over head cams need a bit more cooling power, hence the full lenght dual core. If you do chose the run the smaller radiator, you should watch your engine temp gauge regularly.
HTH
Old May 4, 2004 | 07:57 PM
iwhichisme's Avatar
thats kinda what i was thinking, but ive done a swap on a 91 si using a b16a and the stock radiator worked fine. I also have a EG with a dohc swap in it, and i have been using the puney stock rad. since the swap was done. THats why i was kinda wandering if i could use that combo on a da. I just didnt know if it would actually bolt up.
peace,
GILBY
Apr 11, 2016 08:54 AM
EF9_RIDER37
Apr 3, 2010 08:57 PM
sasinorm01
Feb 21, 2007 07:16 PM
iwhichisme
May 4, 2004 09:07 PM
