o2 Sensor problems
Old May 6, 2004 | 06:20 PM
GsrTeggy's Avatar
Default o2 Sensor problems
i purchased a obx high flow cat. when i went to install it i noticed the stock cat had a hole in the top and the obx cat was at the bottom. in that case the o2 sensor wasnt long enough. so i cut the cable an extened it and put it together. statered my car and check engine light came on. i checked with a computer and it said it was my o2 sensor. any ideas.
thanks
Old May 6, 2004 | 06:55 PM
Train's Avatar
Default Re: o2 Sensor problems (GsrTeggy)
dont cut 02 sensor wires.... they're specific voltage, amperage, and resistance. if you change this it will cause the signal to be off. i'd say find an oxygen sensor that has wires long enough and the correct plug. (like from a DA if you're OBD1)
Old May 6, 2004 | 09:03 PM
blitzteggsr's Avatar
what if you cut the o2 sensor wires to install a universal o2 sensor? would that be a problem?
Old May 7, 2004 | 12:18 AM
coil222's Avatar
Default Re: (blitzteggsr)
bump
Old May 7, 2004 | 09:51 AM
zilverz's Avatar
o2 sensor on the bottom? thats retarded /: most of us is rollin around dropped.... lets just shave our O2 sensor off on a speed bump
i would send the, cat, back and ask for one welded on top.... if they wont .. just buy a test pipe with the o2 on top
Old May 7, 2004 | 10:20 AM
frenchy's Avatar
Default Re: o2 Sensor problems (zilverz)
did you just mount it upside down? - if its mounted right go to a muffler shop and have them cut/flip/reweld, and bingo
EDIT - do you mean top/bottom or front/back?
Old May 7, 2004 | 11:38 AM
GsrTeggy's Avatar
ya i have never seen an o2 sensor on the bottom. but it doesnt get in the way of anything. if i buy the universal does any one have a pic of the connector for obd1.
Old May 7, 2004 | 07:41 PM
gsrboi80's Avatar
if your obd2 you are going to throw a code even if the bung is at the top and you didnt splice the wires. you will definitly throw code 67.
Old May 7, 2004 | 10:46 PM
Default Re: o2 Sensor problems (gsrboi80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboi80 &raquo;</TD></TR><TR><TD CLASS="quote">if your obd2 you are going to throw a code even if the bung is at the top and you didnt splice the wires. you will definitly throw code 67.</TD></TR></TABLE>
why would he throw a code?
Old May 9, 2004 | 08:53 PM
diogo6's Avatar
Default Re: o2 Sensor problems (blitzteggsr)
because the o2 #1 gain is above 9.7, and no the code should not go off, this is very freaky... good luck man, let me know if you need more help
Old May 9, 2004 | 08:58 PM
Trac226's Avatar
Default Re: o2 Sensor problems (diogo6)
O2 sensors are pretty troublesome because of the speed they sample, but I haven't had any problems when extending the wires on an o2 sensor. I would really go back and check your wiring, you might have swapped the heater side.
Old May 10, 2004 | 12:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diogo6 &raquo;</TD></TR><TR><TD CLASS="quote">because the o2 #1 gain is above 9.7, and no the code should not go off, this is very freaky... good luck man, let me know if you need more help</TD></TR></TABLE>
I am obd2 and I replaced my o2 sensor with a universal bosch and haven't thrown a code. I tried to cut the wires so that it was the same length as OEM.
janek
Dec 4, 2008 06:36 PM
EJ8 Kenobi
14
Feb 25, 2008 08:59 PM
JoshRambo
May 15, 2003 01:09 PM
ldodol
Mar 29, 2003 01:24 PM
:jdmshmaydm:
Sep 19, 2002 04:57 AM
