timing issues.....tdc?
Old May 4, 2004 | 11:52 AM
CTRwannaB's Avatar
Default timing issues.....tdc?
when the arrows are pointing up on the cams does the marker have to point to one of the etches/markings on the carnk?
or is the marking supposed to lined up with the black cover thing and the arrows pointing down?
well hopefully someone knows what i am babbling about.
o yea this is for 94 ls b18b
Old May 4, 2004 | 12:15 PM
95BlkGSR's Avatar
Default Re: timing issues.....tdc? (CTRwannaB)
how many miles does ur car have on it, cause my uncle works at honda and when they hit about 90,000 to 110,000 they need new timing belts put on and they will run like new and last for about 150,000 miles more, my dad has a accord with 276,000 miles and its still strong, so if u have high miles get it replaced, my opinion from what i no,
i havea 95 gsr w/100,000 miles i had it done and everything is perfect now
ask some other people, but id get that checked if it was me
Old May 4, 2004 | 12:46 PM
mr.beeks's Avatar
Default Re: timing issues.....tdc? (95BlkGSR)
well the marking is between 10 and 11 oclok
thats what you have to line up you crank to....
Old May 4, 2004 | 01:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
With the arrows pointing up on the cam gears, the white mark on the crank pulley is supposed to line up with the pointer on the lower timing belt cover.
When you install the timing belt (lower cover and crank pulley are off) there is a mark on the lower timing belt crank pulley that lines up with a mark on the oil pump.
jdmthug
Aug 22, 2009 07:09 AM
Danronian
Apr 12, 2006 03:06 PM
94dxt
Oct 27, 2004 12:36 PM
R.S.
Oct 11, 2004 03:12 PM
JONBLAZE55555
Nov 27, 2003 12:46 PM
