Brake problem
Searched and couldnt find anything exactly like what I have. My 90 teg gs has intermitant braking problems. Sometimes there is really good brake pressure, and sometimes the pedal will go to the floor and I have to keep pumping it to stop completely. Could this be from a dirty wheel sensor? Any suggestions would be great.
That's not the wheel sensors. It's either air in the brake system or a bad master cylinder. I'm guessing if you bleed your brakes it'll help for a short time but won't really fix the problem. You probably need a new master cylinder.
Im going to check the ABS rings on my axles sometime this weekend. The pedal doesnt just drop to the floor, but it slowly geeps drpressing until right before i stop, then it bottoms out. Maybe i will also flush the brake fluids, i guess there could be moisture in the system. Wont a bad master cylinder ba associated with leaking or low brake fluid. My fluids are fine, not losing any as far as I can tell, and dont see any leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">That's not the wheel sensors. It's either air in the brake system or a bad master cylinder. I'm guessing if you bleed your brakes it'll help for a short time but won't really fix the problem. You probably need a new master cylinder.</TD></TR></TABLE>i second that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth civic »</TD></TR><TR><TD CLASS="quote">Im going to check the ABS rings on my axles sometime this weekend. The pedal doesnt just drop to the floor, but it slowly geeps drpressing until right before i stop, then it bottoms out. Maybe i will also flush the brake fluids, i guess there could be moisture in the system. Wont a bad master cylinder ba associated with leaking or low brake fluid. My fluids are fine, not losing any as far as I can tell, and dont see any leaks.</TD></TR></TABLE>
dang, my 94 GS-R does the EXACT same thing, sometimes it feels fine and other times it will sink. I flushed my brake fluid in March, and I'm thinking my friend may have pushed the brake pedal too hard (pushed down too far) causing dirt on the piston to get into the seals. I need to replace my MC I know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth civic »</TD></TR><TR><TD CLASS="quote">... Wont a bad master cylinder ba associated with leaking or low brake fluid. My fluids are fine, not losing any as far as I can tell, and dont see any leaks.</TD></TR></TABLE>The way most MCs fail is the leak bypasses the piston seal. It doesn't leak OUT, it leaks back into the reservoir.
It sound like it's NOT your ABS in any way at all. Besides, your ABS would throw a code if a wheel sensor were messed up.
S_F
19
Feb 15, 2010 02:10 PM
