eradic idle...HELP
Old May 6, 2004 | 09:25 PM
zickyicky's Avatar
Default eradic idle...HELP
my 95 idles eradically. any ideas?
Old May 7, 2004 | 09:59 AM
zilverz's Avatar
Default Re: eradic idle...HELP (zickyicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zickyicky &raquo;</TD></TR><TR><TD CLASS="quote">my 95 idles eradically. any ideas?</TD></TR></TABLE>
Vac Leak ? Check ever single hose make sure they are all plugged into the proper location.
Adjust your Idle screw set idle to 750-800rpm range.
Check the IM gasket... have friend spray some .. Carb cleaner around the gasket while you rev the car up ... see if it sucks it up around the gasket
Has your Throttle plate been adjusted recently? it need to be set properly.
Throttle body gasket is another seal to check
Take off the IACV clean it with carb cleaner .. put it back on.
Does your TB have a FITV on it ?
this chitzz should keep you busy for a while
Old May 7, 2004 | 10:06 AM
frenchy's Avatar
Default Re: eradic idle...HELP (zilverz)
search idle problems - that should keep you real busy
Old May 8, 2004 | 06:32 PM
zickyicky's Avatar
thanx alot guys....i appreciate it
DerekHollister
Apr 7, 2016 09:50 AM
Hardedge
Dec 9, 2007 09:18 AM
go2sleep
Jun 27, 2006 01:36 PM
SimplyTron
Jan 31, 2006 04:05 AM
2fknlo
Sep 13, 2004 01:15 PM
