1989 ACURA INTEGRA code reader
Old May 4, 2004 | 05:27 PM
chrisnova's Avatar
Default 1989 ACURA INTEGRA code reader
Does anyone know where to buy an ECU code reader for an 1989 ACURA Integra?
Or perhaps an inexpensive place to get it read?
Thanks.
Old May 4, 2004 | 05:39 PM
GG-SquadDB's Avatar
Default Re: 1989 ACURA INTEGRA code reader (chrisnova)
Autozone ...free dude
Old May 6, 2004 | 11:06 AM
chrisnova's Avatar
Default Re: 1989 ACURA INTEGRA code reader (GG-SquadDB)
Thanks, but Autozone only does 1996 and up.
Thanks anyway.
Old May 6, 2004 | 11:10 AM
G1 TEGGY's Avatar
here's the codes, https://honda-tech.com/zerothread?id=838322
just jump the wires, there's info on how to do that in the thread too.. it's free, unless you need to buy a paper clip
Old May 6, 2004 | 05:26 PM
Weston's Avatar
If it's like my '90 Prelude, there is a light on the ECU itself that flashes out the code... (it doesn't flash the code with the CEL in the gauge cluster)
Old May 7, 2004 | 05:53 PM
chrisnova's Avatar
Default Re: 1989 ACURA INTEGRA code reader (G1_TEGGY)
Thanks for the information. I checked for the LED and found 9 flashes a pause and 9 more. I presume based on the code that it has to do with the no. 1 cylinder crank angle. I checked the connector outlined inthe Haynes manual (which also indicated Crank angle ) however the 2 contacts check out with 435 ohms within range and there is no ground short (no continuiaty between any of the 2 contacts specified. I guess the unit checks out. The manual said to go see the dealer if it passes and the check engine light for crank angle sensor still stays on. I guess that is what I will do unless someone else knows any tricks. One other thing I should mention is the that the check engine light comes on intermittently (about half the time). The car runs rough at partial throttle (just above idle) and the plugs are dark and apear carbonized. It seems like it is running on a rich mixture if I had to take my best guess. Anything else I should check before heading to the dealer and getting soaked?
Thanks for your input! Much appreciated.
Old May 7, 2004 | 05:54 PM
chrisnova's Avatar
Default Re: (Weston)
Thank you. I found 9 LEDs flashing. Loooks like crank angle sensor.
t-splice.mn
Jul 1, 2008 01:00 PM
typesguy
Aug 9, 2007 10:22 AM
DOHCon15s
Sep 30, 2003 06:38 AM
CBR600OnTop
Jul 3, 2003 01:14 PM
