Timing Question
Old Jul 4, 2004 | 04:16 PM
T--Rex's Avatar
Default Timing Question
How do you know if your timing belt is off a tooth or so. I am currentley having a problem with my engine whare it won't rev over 3000 rpms, someone suggested i check the timing, i played with the destributor and it does'nt seem to make any difference. If I was off a tooth would that stop it from reving over 3000 rpms? Is there any easy way , besides taking off the side covers and the valve cover to see if the timing belt was off?
Old Jul 4, 2004 | 08:30 PM
King_j's Avatar
Default Re: Timing Question (Matrix_Zero)
taking off those covers is easy.
adjusting the distributor only does MINOR adjustments.
what did you do to your car in order for it not to exceed 3000 rpm?
Old Jul 5, 2004 | 09:17 AM
T--Rex's Avatar
Default Re: Timing Question (King_j)
Just swapped it into the car. Actually it was swapped into a 88 crx dx.
Old Jul 5, 2004 | 09:42 AM
3.504's Avatar
if its a jdm motor that you swapped into your crx (like an sir1 b16) i'd say check plugs/wires. the wires that came on my b16 and my buddies b16 were so bad it wouldn't let the motor rev just like yours. as soon as i got new wires, ran perfect. then i went ahead and did the rest of the tune up for reassurance.
Old Jul 5, 2004 | 11:04 AM
skunk2eg's Avatar
Default Re: Timing Question (3.504)
what motor is it?
it could be the motor/ecu combo that u are running....
when my timing belt skipped a tooth it bogged down really bad and the powerband was off
GoodSpeed150
Mar 2, 2011 06:34 AM
UGOT8UP2
23
Feb 18, 2009 07:53 PM
xlasianizelx
Mar 24, 2008 10:54 PM
T--Rex
Jul 5, 2004 09:35 AM
T--Rex
Jul 4, 2004 04:18 PM
