cant pull CEL codes
Old Jul 4, 2004 | 10:27 PM
LostAndFound's Avatar
Default cant pull CEL codes
Well I know how to pull codes, and was able to pull the ABS code, but my CEL is on and I cant pull the code. I try but it doesnt flash. It did this before too, then Idisconnected the o2 sensor and it threw the code that its missing the o2 sensor. Now I replaced it with a working one and the light is on again. The car does have a JDM swap, everything seems right and everythin feels right, with the exception that if I touch anything electrical at idle the idle does drop. IE - roll up the windows or flash the highbeams it drops about 100 RPMs. Im thinking maybe thats the alternetor.
But other then that the car runs and p ulls good, damn this CEL.
PS- I did reset the ECU after I got the new o2 sensor. any ideas?
Old Aug 28, 2006 | 08:21 PM
averyvm's Avatar
Default Re: cant pull CEL codes (LostAndFound)
ttt just want to know what you guys might think the answer is to this problem
Old Aug 29, 2006 | 07:19 AM
VTECth1s's Avatar
Does the CEL continously stay on even if you try jumping it? just stays solid? if so...you got a FAULTY/BAD ECU, get a new ecu or chipped ecu.
HommeDeBois
15
Jul 16, 2011 02:56 PM
killaj12
Mar 5, 2007 04:16 AM
MindLess311
Jul 2, 2006 05:36 PM
Nuts
Apr 21, 2004 09:01 AM
MintyDip
Jan 21, 2002 09:37 AM
