bogging
Old Jul 6, 2004 | 06:04 PM
ninjaturtle1023's Avatar
Default bogging
hey guys im new here. i just swapped a jdm b16a in my 91 teg. when im drivin it sounds like the motor is gargling at 3rpms-4rpms, at 5rpms she stops bein sluggish and she hauls ***.
somebody help
I have new accell ignition wires, new spark plugs, new timing belt, and an exedy clutch.
Old Jul 6, 2004 | 08:45 PM
mr.beeks's Avatar
Default Re: bogging (ninjaturtle1023)
sounds to me that its off timming
double check your crank and cam gears.....
Old Jul 6, 2004 | 08:52 PM
3.504's Avatar
Default Re: bogging (mr.beeks)
my buddies DA w/ a b16 all obd0 does that and my 93 da w/ obd0 b16 ran w/ my pr4 does that. dont know what it is... but timing is on in my motor and we've tried 3 distributors on his and timed it a few times. boggles my mind, it still runs good otherwise. hopefully someone can come up with somethin
Old Jul 6, 2004 | 09:59 PM
Fuuma0083's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me that its off timming
double check your crank and cam gears.....</TD></TR></TABLE>
Old Jul 7, 2004 | 12:14 AM
3.504's Avatar
Default Re: bogging (Fuuma0083)
check and double checked. also have the all new wires, plugs, cap and rotor. fuel injectors are clean, but not brand new.
Old Jul 7, 2004 | 10:55 AM
i took it to a mechanic of mine and he said he thinks the igntion wires are heat soaking. he told me to buy honda ignition wires instead of keeping my accel ignition wires.
somebody holla back
91 DA B16a Bogging
Old Jul 7, 2004 | 11:24 AM
Darkane's Avatar
Default Re: bogging (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">my buddies DA w/ a b16 all obd0 does that and my 93 da w/ obd0 b16 ran w/ my pr4 does that. dont know what it is... but timing is on in my motor and we've tried 3 distributors on his and timed it a few times. boggles my mind, it still runs good otherwise. hopefully someone can come up with somethin</TD></TR></TABLE>
you ran a non-vtec ecu on you B16?? PR4 is B18B if im not mistaken? I thought it would barely run and throw codes like crazy?
angrysmileyface
11
Jun 2, 2015 04:41 AM
teamredline9k
May 29, 2006 06:12 PM
slammedef06
Apr 11, 2006 05:26 PM
SiR Vtec X
Oct 12, 2005 07:04 PM
rhapsody28
Jul 18, 2003 06:01 AM
