9005 headlight conversion
Old Jul 5, 2004 | 01:11 PM
CNSK's Avatar
Default 9005 headlight conversion
I recently did a 9005 sylvania silverstar bulb conversion to my headlight, since everyone said its the closest to HID's you'll ever get for $40 and seems like is not even as bright as my old 9006 catz bulb I bought 2 years ago. I put one side for catz and one side for the silverstar and I like the 9006 catz bulb and it's brighter also. Dont get me wrong I tested the stock one's too and yes the silverstar is brighter but I still think my old 9006 catz are better. But still to the silverstars....
Old Jul 5, 2004 | 01:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 9005 headlight conversion (DrMartin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">I recently did a 9005 sylvania silverstar bulb conversion to my headlight, since everyone said its the closest to HID's you'll ever get for $40 and seems like is not even as bright as my old 9006 catz bulb I bought 2 years ago. I put one side for catz and one side for the silverstar and I like the 9006 catz bulb and it's brighter also. Dont get me wrong I tested the stock one's too and yes the silverstar is brighter but I still think my old 9006 catz are better. But still to the silverstars....</TD></TR></TABLE>
The Catz bulbs must have been over-wattage bulbs. A 9005 conversion will ALWAYS be brighter than 9006 bulbs, period, assuming stock wattage on each and no crazy blue bulb tints and such.
Old Jul 6, 2004 | 01:54 PM
Gerbilo's Avatar
Default Re: 9005 headlight conversion (PatrickGSR94)
My friends 9005 silverstars are much brighter than my stock 9006s, going to do the conversion soon myself
Old Jul 6, 2004 | 02:08 PM
..::91TEG-G2::..'s Avatar
Default Re: 9005 headlight conversion (Gerbilo)
how exactly do you do this conversion? dont you just get the bulb, and on the plastic housing on the bulb, you trim off a couple of peices or somethin?
can someone do a write up with maybe some pics too?
Old Jul 6, 2004 | 02:14 PM
silver00teg's Avatar
i did the 9005 conversion last night on my car with just some cheap bulbs...and it made a big difference over stock
Old Jul 6, 2004 | 02:15 PM
Default Re: 9005 headlight conversion (silver00teg)
check patrickgsr94's sig
Old Jul 6, 2004 | 02:31 PM
ok, so i do this conversion.. i got a DA so thats 9004.. would it be the same proceedure as 9006-9005's?
and do i have to worry about melting anything? and is there a way to take off the headlight housings and clean the inside of them from any dust? as the guy that did the write up said he had a little bit of dust on the "mirror" part, cleaned it off and everything worked better?
Old Jul 7, 2004 | 05:59 AM
Community Builder
Default Re: 9005 headlight conversion (..::91TEG-G2::..)
You can't do it on DA's, this is only for cars that use 9006 bulbs for the low beams.
Old Jul 7, 2004 | 06:45 AM
yourmom25's Avatar
Have you experienced any problems with heat? I don't want to melt the housing. I understand the 9005 bulbs are also in the highbeams, but wanted to make sure there weren't any problems before i did the conversion.
Old Jul 7, 2004 | 09:59 AM
Community Builder
Default Re: 9005 headlight conversion (yourmom25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yourmom25 &raquo;</TD></TR><TR><TD CLASS="quote">Have you experienced any problems with heat? I don't want to melt the housing. I understand the 9005 bulbs are also in the highbeams, but wanted to make sure there weren't any problems before i did the conversion.</TD></TR></TABLE>
The bulbs won't last as long as 9006, but that's about it. When I had the 9005 conversion w/ Sylvania Cool Blues, they lasted 1.5 years before 1 burned out, which is very reasonable considering you get a 70% increase in light over stock 9006, and a pair of Cool Blues costs less than $20 most places.
Old Jul 7, 2004 | 10:11 PM
Gerbilo's Avatar
I just did the 9005 conversion for my car tonite, i'm going to upload pictures and get a small write up done, when I do, i'll post a link here for ya
Old Jul 7, 2004 | 10:31 PM
RiCeRTeG's Avatar
Default Re: 9005 headlight conversion (Moua)
what for the 9005 conversion dun you have to used your high bleam everytime you drive though???
Old Jul 8, 2004 | 12:22 AM
Gerbilo's Avatar
Default Re: 9005 headlight conversion (RiCeRTeG)
What you said makes very little sense, but from what I can gather...
9005 is what the high beam bulb is. You are putting the same kind of bulb in your low beam lights. At that point you have the same bulb in high and low beam. The difference is the beam path. Highs are aimed high, and lows are aimed low. go figure...
You can still click your "brights" on and it will be much brighter since they are aimed off the ground.
Old Jul 8, 2004 | 12:25 AM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">Highs are aimed high, and lows are aimed low. go figure...</TD></TR></TABLE>
I wonder if you ever noticed that Integra's have halogen-based PROJECTORS for the low beams... What do you think happens when you use 9005s in place of 9006 bulbs?
You go figure.
Old Jul 8, 2004 | 12:41 AM
Gerbilo's Avatar
Default Re: 9005 headlight conversion (NightRider-gsR)
??? They are still cut off at a low point if that's what you meant.
Still the 3 tier lighting
Old Jul 8, 2004 | 12:45 AM
Gerbilo's Avatar
I'm also not a lighting guru.....
Old Jul 8, 2004 | 01:05 AM
Gerbilo's Avatar
https://honda-tech.com/zerothread?id=919047
for my lil writeup
Old Jul 8, 2004 | 01:58 AM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">I'm also not a lighting guru.....</TD></TR></TABLE>
You may not be a lighting guru but for doing a writeup at 2 am
You have just redeemed yourself...have a
NRg
Old Jul 8, 2004 | 02:02 AM
Gerbilo's Avatar
lol, thanks
It's the first writeup of any kind i've done so, good to hear it's not terrible but yeah, I didn't even realize it was this late until I got towards the end and looked at the clock. I wanted to get it done tonite otherwise I knew i'd probably get lazy and never get around to finishing it.
for you as well, I can't be drinkin alone now can I? haha
Old Jul 8, 2004 | 09:55 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">Still the 3 tier lighting</TD></TR></TABLE>
3 tier lighting?
If you mean it looks like the cutoff has 3 levels, your headlights are aimed wrong. The low side of the cutoff on both projectors should be at the same level (~2.1" below horizontal at 25 ft. away), and the high side of the cutoff should be the same on both projectors, like this (Benz E-class bi-xenon projectors in my Teg pictured):
Old Jul 8, 2004 | 11:14 AM
Gerbilo's Avatar
The left side of my light pattern is lower than the center, which is lower than the right, not by much though. Thought it was an effort not to blind oncoming traffic.
Old Jul 8, 2004 | 11:20 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">The left side of my light pattern is lower than the center, which is lower than the right, not by much though. Thought it was an effort not to blind oncoming traffic.</TD></TR></TABLE>
If you block one headlight and look at the beam pattern of the other one, each individually, you'll notice each has a "step" pattern with the lower side being towards the left. Both headlights should be aimed to the same height, so that the cutoff looks similar to this:
_________o-------------___________o-------------
It should NOT look like this:
_________o----------------------------oŻŻŻŻŻŻŻŻŻŻŻ
Old Jul 8, 2004 | 11:23 AM
Gerbilo's Avatar
ahh, i'll have to check it out next time I get a chance. The passenger side light must be aimed slightly higher than the other.... or i'm blind!
Old Jul 8, 2004 | 12:56 PM
Smeeg Heed's Avatar
I noticed a huge difference when I went from OEM 9006 to Sylvania silverstar 9005. They still aren't HIDs though
Old Jul 9, 2004 | 12:37 AM
Gerbilo's Avatar
Default Re: 9005 headlight conversion (Smeeg Heed)
I've driven more at night now w/ the 9005 conversion(i'm on night 2 now heh) and the light doesn't project further, but the area that it does project upon is definitely brighter and whiter
