OBD2->OBD1 issues
Old Jul 6, 2004 | 02:49 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default OBD2->OBD1 issues
hey, i just bought an LS out of a crashed teg, its an obd2, and i plan to swap it into my 5g civic which happens to be obd1, since im using my stock wiring, would it be possible to get an ECU from a obd1 teg and use it to run the engine?? any help would be greatly appreciated
Old Jul 6, 2004 | 03:08 PM
wreckedmyteg's Avatar
Default Re: OBD2->OBD1 issues (turtlecx92)
Yes, but you'll need a OBD1 wiring harness.
Old Jul 6, 2004 | 03:39 PM
Cain Marko's Avatar
Default Re: OBD2->OBD1 issues (wreckedmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but you'll need a OBD1 wiring harness.</TD></TR></TABLE>
like the obd1 wiring harness from my car?
Old Jul 7, 2004 | 01:44 PM
Cain Marko's Avatar
anyone?
Old Jul 7, 2004 | 02:10 PM
Cramerox's Avatar
you need a obd2 to obd1 wires harnest. you get one for about 150 bucks. this will let you run an obd1 ecu in your obd2 car. get it?
Old Jul 7, 2004 | 02:12 PM
I'm not sure if the stock motor in your civic uses the same wiring harness as the integra motor.
Old Jul 7, 2004 | 02:14 PM
Cramerox's Avatar
yes you bring up a good point....
Old Jul 7, 2004 | 02:27 PM
Cain Marko's Avatar
Default Re: OBD2->OBD1 issues (Cramerox)
i know about the obd harness converter, its 125$ shipped from JDMsh!t.com, the only issue for me is, you cant retain your stock ecm location, i was just trying to see if there was another route
Old Jul 7, 2004 | 02:36 PM
Cain Marko's Avatar
eh screw it, im just gonna get the converter, my friend said my civic harness isnt the same, my other friend mentioned something about if i take the integra dashboard then it will all be good and i wont need any converter, is this true or is he on crack??
Old Jul 7, 2004 | 02:39 PM
iH8RICERZ's Avatar
if your car is already an obd 1 civic, then you can basically run any obd 1 ecu on that motor.....just plug and play! I have an obd 1 LS ecu for sale...pm me if your interested!
Old Jul 7, 2004 | 02:40 PM
Cain Marko's Avatar
Default Re: OBD2->OBD1 issues (iH8RICERZ)
even if the motor is obd2??
ELIT3
Aug 6, 2009 02:55 PM
advan414
Feb 25, 2008 02:28 PM
danxdan
Jul 13, 2005 03:37 PM
Glen Tennis
Dec 17, 2003 06:06 AM
Erik_Pb_Foot
Oct 15, 2001 09:52 AM
