Converting compression test results
Just tested my B18C1 w/ CTR pistons and massive headwork done and got these numbers:
260
255
250
260
Its within the parameters of good compression, just wondering how i would go about converting that number to the actual compression ratio. Also, is that lower than it should be for an engine that should be 12.1:1?
Thanks
260
255
250
260
Thanks
Well you're compression #s are going to vary with your cam selection. Either way, a stock gsr runs around 200s(like 220 new I think) so you're looking good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 »</TD></TR><TR><TD CLASS="quote">Just tested my B18C1 w/ CTR pistons and massive headwork done and got these numbers:
260
255
250
260
Thanks</TD></TR></TABLE>
You can't determine compression ratio from compression test results.
Use the calculator on c-speedracing.com and see what you get.
260
255
250
260
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 »</TD></TR><TR><TD CLASS="quote">we got 280 psi accross the board on a motor that shoulda been around 12.5:1</TD></TR></TABLE>
mine is suppose to be 11.8:1 but i pinned 300psi per cylinder
Nextelbuddy
Jan 9, 2004 06:18 PM
