JDMShit.com 5 Speed Conversion Mount Issues!!!!
Old Jul 7, 2004 | 04:32 PM
ferio 95's Avatar
Default JDMShit.com 5 Speed Conversion Mount Issues!!!!
Ok i orderd the EG-AT mount which is needed to do a 5 speed conversion in a eg or dc from JDMShit.com. The problem is the **** wont fit. It bolts on to the tranny no problem, but the rubber mount is to far forward so it wont fit. we have tried everything but nothing is working. We called JDMShit.com and the tell us that numerous people have called saying it dont work, and they reply that we need to put that mount in last and leave the other mount loose and it will slide right in. Well that **** dont work. So if anyone has had this problem and got it work let me no asap!
Old Jul 7, 2004 | 04:51 PM
Bspec18's Avatar
Default Re: JDMShit.com 5 Speed Conversion Mount Issues!!!! (ferio 95)
have you tried installing the mount to the frame first and then to the tranny ? Or threading a little on to the tranny first then to the frame ?
Old Jul 7, 2004 | 06:23 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: JDMShit.com 5 Speed Conversion Mount Issues!!!! (Bspec18)
How far forward is it? Just a tiny bit? Or about 5 inches or so?
If it's a lot, it might be the wrong mount. Keep in mind, the frame mount on the chassis is in a different location on a automatic car and a manual car.
You probably knew this already though. Hehe.
Old Jul 8, 2004 | 12:41 AM
ferio 95's Avatar
Default Re: JDMShit.com 5 Speed Conversion Mount Issues!!!! (shamoo)
The hole that the long 17mm bolt goes into is about a inch off. We had it in place but it caused the driver side mount to stretch and it looked as though one launch from the 4 puck stage 5 clutch i have installed would bust it wide open. we rigged up something to work in its place though. A freind of ours who owns a shop tipped us on how he used automatic brakets to work ill post pics later on how we did it and the horrible fitment issues
Old Jul 8, 2004 | 01:36 AM
ferio 95's Avatar
Here are the pics that i posted on local forum
http://www.houston-imports.com...42900
Old Jul 9, 2004 | 07:48 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You need to put the motor in the same way as any other motor swap..... tighten the rear crossmember mount, tighten the transmission bracket, start the bolts on the tranny mount. Put the motor in and first bolt the rear tranny bracket to the rear mount but just start the bolt and don't torque it down (if you tighten any bolts down, which is sounds like you're doing, then the motor will be very hard to move around). After the rear is in, then do both sides.... put the tranny mount in and put the driver side mount in but just start the bolts, don't tighten down yet. After you get the motor mounted in and the bolts started, now tighten them all down to spec.
A common problem people always run into when doing the EG-AT mount swap, if the motor is already in, is that they don't loosen up the other motor mounts and then complain that the mount is off. With any motor mounts, stock or aftermarket, if you don't loosen anything up it'll be next to impossible to move the motor around into the position that you want it in. If you've done motor swaps in the past, then you know what I'm talking about.
Old Jul 9, 2004 | 10:18 AM
wreckedmyteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">Here are the pics that i posted on local forum
http://www.houston-imports.com...42900</TD></TR></TABLE>
I noticed that car was on jacks only and no jack stands....pretty stupid.
Old Jul 9, 2004 | 10:51 AM
locash's Avatar
Default Re: JDMShit.com 5 Speed Conversion Mount Issues!!!! (wreckedmyteg)
The problem is that the mount is made for a 92-95 Civic ONLY. It will not fit the Integra chassis. Return it, I think only Hasport makes the mount you are looking for.
-joe
Modified by locash at 8:45 PM 12/19/2004
Old Jul 9, 2004 | 12:37 PM
ferio 95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">You need to put the motor in the same way as any other motor swap..... tighten the rear crossmember mount, tighten the transmission bracket, start the bolts on the tranny mount. Put the motor in and first bolt the rear tranny bracket to the rear mount but just start the bolt and don't torque it down (if you tighten any bolts down, which is sounds like you're doing, then the motor will be very hard to move around). After the rear is in, then do both sides.... put the tranny mount in and put the driver side mount in but just start the bolts, don't tighten down yet. After you get the motor mounted in and the bolts started, now tighten them all down to spec.
</TD></TR></TABLE> Ive swaped motors enough to no what im doing and that method dont work the mount is like a whole inch off
It stretches the driver side mount to the point that it will bust easly. Im sending the mount back in return for my money. Also there are no marking's on the mount to say what it is. FOr all we no it could have been a EF mount for b series motors who knows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that car was on jacks only and no jack stands....pretty stupid.</TD></TR></TABLE>
The car was on jacks stands off and on because we had to raise and lower the car often. You should think before opening your mouth to show how much of a dumbass you are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">The problem is that the mount is made for a 92-95 Civic ONLY. It will not fit the Integra chassis. Return it, I think only Place Racing makes the mount you are looking for.
-joe</TD></TR></TABLE>
Then why advertise that its for Civic's and Integra's?
Direct qoute from http://www.JDMShit.com
"EG-AT Transmission Mount (For Auto Chassis)
Fits 92-95 Civic, 94-01 Integra, 93-97 Del Sol"
This is what i had to come up with to get the car to at least run till i can get a solid mount made
Its the product of a normal auto b series bracket and the little adapter braket cut in half with some washers
Modified by ferio 95 at 9:51 PM 7/9/2004
Modified by ferio 95 at 1:33 AM 7/11/2004
Old Jul 9, 2004 | 09:16 PM
mikesrex's Avatar
Default Re: JDMShit.com 5 Speed Conversion Mount Issues!!!! (Newman)
I helped the owner of the car with this swap. There is NO way this mount would work on his car. I've done 2498572497697 honda swaps and know that the mount doesn't fit.
locash is probably right about it only being for civics and not integras.
Thanks to Huy from Inline Racing in Houston for the very helpful insight on how to make the stock auto mount fit with a little bit of fabbing. I owe you one man.
TwentyTwo91
May 7, 2011 04:10 AM
atleast-3
Sep 23, 2007 12:07 AM
Haruspex
Feb 19, 2005 08:51 AM
ferio 95
Jul 9, 2004 12:55 PM
