need answer quick
Old Jul 22, 2004 | 12:53 PM
dAng! Kris's Avatar
Default need answer quick
I have a bad surgin idle. I just changed the throttle body cuz i thought it was the tps. Any other things it might be??? need answer asap
Old Jul 22, 2004 | 01:20 PM
.water's Avatar
Default Re: need answer quick (Frozty)
check ur TB cable...make sure cable is not too tight...,,also change ur idel level
Old Jul 22, 2004 | 01:21 PM
Slo Car's Avatar
vacuum leak?? don't know...be more descriptive about the problem....
Old Jul 22, 2004 | 01:25 PM
dAng! Kris's Avatar
Default Re: need answer quick (Slo Car)
all vacuum hoses are hooked up and no holes, throttle body cable is fine, and the idle adjustment is at lowest setting and wont change with adjustment. I'm trouble shooting other things now, thanks for the help. LMK if anyone has any imput
Old Jul 22, 2004 | 03:13 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frozty &raquo;</TD></TR><TR><TD CLASS="quote">all vacuum hoses are hooked up and no holes, throttle body cable is fine, and the idle adjustment is at lowest setting and wont change with adjustment. I'm trouble shooting other things now, thanks for the help. LMK if anyone has any imput</TD></TR></TABLE>
mine surges sometimes too... it was running hella rich at idle... mmmm vafc2
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
tbuck23
Apr 5, 2007 05:00 PM
FlatLineEG8
Mar 4, 2004 04:47 PM
stock97
Aug 14, 2003 10:14 PM
eknine
Jul 10, 2003 08:36 AM
