best struts?
Old Jul 22, 2004 | 07:15 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default best struts?
jic maybe?
Old Jul 22, 2004 | 08:30 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: best struts? (FastAllmotorLsVtec)
bump
Old Jul 22, 2004 | 09:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
best shocks you mean? I vote for Koni Sports best off the shelf stock replacement shock anyway.
Old Jul 22, 2004 | 09:11 AM
Circuit Star-29's Avatar
Default Re: best struts? (PatrickGSR94)
Bilstein SPORT has my vote. Extremely firm and is a great match with H&R RACE springs or something as stiff or stiffer. Excellent street/track setup. And JIC is not that good. Don't buy them. There is a post somewhere on here about them and being tested on a shock dyno. I'll try to find it.
Old Jul 22, 2004 | 09:12 AM
ponytd's Avatar
best for what? racing, street, racing/street, daily driver?
Old Jul 22, 2004 | 09:14 AM
Default Re: best struts? (ponytd)
https://honda-tech.com/zerothread?id=878754
This is the thread I was talking about...JIC .
Old Jul 22, 2004 | 09:15 AM
Community Builder
Default Re: best struts? (nathan atwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">Bilstein SPORT has my vote. Extremely firm and is a great match with H&R RACE springs or something as stiff or stiffer. Excellent street/track setup. And JIC is not that good. Don't buy them. There is a post somewhere on here about them and being tested on a shock dyno. I'll try to find it.</TD></TR></TABLE>
Okay well Bilstein Sport = best OTS non-adjustable shock, and Koni Sport = best OTS adjustable shock. The two probably shouldn't be directly compared as they're different animals.
Old Jul 22, 2004 | 09:24 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Okay well Bilstein Sport = best OTS non-adjustable shock, and Koni Sport = best OTS adjustable shock. The two probably shouldn't be directly compared as they're different animals.</TD></TR></TABLE>
well the best choice of strut/shock would have to be based on your wallet. koni's are the best but also the most money out of all of them.
i got illumina's, and for 369 shipped, and there adjustable too, as you probably know. and i dont see any difference from koni's.. the only thing i think koni's are good for is the adjustable ?pertch? so you can get that perfect drop.
also what kind of springs are you going to be using, so we could help you pair you up with a good set of shock/strut's
Old Jul 22, 2004 | 12:39 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: best struts? (..::91TEG-G2::..)
racing/street,daily driver,i meant gualinty but c i cant spell if my life depending on it.......
Old Jul 22, 2004 | 12:44 PM
krack's Avatar
what about the tokiko blues??????????????
Old Jul 22, 2004 | 12:54 PM
dip-set's Avatar
Default Re: (KRIZACK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRIZACK &raquo;</TD></TR><TR><TD CLASS="quote">what about the tokiko blues??????????????</TD></TR></TABLE>
top of the line garbage..lol nah there a good oem replacement,for a very very minimal drop..
Old Jul 22, 2004 | 12:55 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (b18b-se)
oh i want an at least 3in drop
Old Jul 22, 2004 | 02:04 PM
Community Builder
Default Re: (FastAllmotorLsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAllmotorLsVtec &raquo;</TD></TR><TR><TD CLASS="quote">oh i want an at least 3in drop</TD></TR></TABLE>
Welp Koni or Bilstein are pretty much your only choices there (depending if you want to be able to adjust damping or not). Pretty much any other shock is going to blow fairly quickly with a 3" drop and the spring rates required to keep the car off the bumpstops with a 3" drop.
Old Jul 22, 2004 | 02:18 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b-se &raquo;</TD></TR><TR><TD CLASS="quote">
top of the line garbage..lol nah there a good oem replacement,for a very very minimal drop..</TD></TR></TABLE>
i have tokiko blues on neuspeed race springs the maximum drop they allow. they are good for daily driving, they arent stiff. they are very similar to stock. if you want a drop and a comfortable ride for driving daily like me through ny/nj then these are excellant shocks.
btw my drop is about 2 1/4 on a db8.
Old Jul 22, 2004 | 02:30 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (IVI)
this are Hayame coil overs their very cool 0-4in drop! only 850
Old Jul 22, 2004 | 02:32 PM
zad5's Avatar
did you want best shock or best coilover best shock my vote is koni yellow because you have to ability to revalve them if u want. i bleieve u can not do this with the bilstein correct me if im wrong i would want to know.
for the hayame coilovers same people make the omniman i believe. but the specs are different on the omniman the valving is better and cost. omnipowerusa.com 699. best coilovers for wut turning all out zeal super function or the buddyclubs. the best of the best is moton but its like 10,000
Old Jul 22, 2004 | 02:35 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (zad5)
i mean coilovers by struts
Old Jul 22, 2004 | 03:08 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAllmotorLsVtec &raquo;</TD></TR><TR><TD CLASS="quote">i mean coilovers by struts</TD></TR></TABLE>
You must mean adjustable coilovers. Terminology is key. A suspension uses both springs and dampers. Shocks and struts are different types of dampers. Integras and Civics use shocks on all 4 corners, not struts. The suspension is a coilover-type suspension, with the coil spring over the damper. There are full (some like to call it "real") adjustable coilovers, which include a damper w/ a threaded body. Then there are adjustable coilover sleeves, which fit over a damper body.
So what are you asking about again?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">
So where did you find that Neuspeed Race springs is the maximum drop Tokico allows on their HP shocks? I wasn't aware that they specified any "maximum" drop. Their valving is very similar to stock, and they WILL be toast in 1-2 years with a low, stiff spring like Neuspeed Race, and I bet you Tokico won't honor the warranty if they know that such a spring was used on them.
My friend used to have Neuspeed Race and Tokico HP's and the ride was absolutely horrible, and they did indeed blow out after about a year. After that he saw the light and got Koni Sports.
Old Jul 22, 2004 | 03:12 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (PatrickGSR94)
ya adjustable coil overs sry we dont think its the same, which adjustable coil overs should i get for atleast an 3in drop
Old Jul 22, 2004 | 03:24 PM
IVI's Avatar
IVI
My friend used to have Neuspeed Race and Tokico HP's and the ride was absolutely horrible, and they did indeed blow out after about a year. After that he saw the light and got Koni Sports. </TD></TR></TABLE>
i was saying that neuspeeds maximum drop is the race spring. the farthest possible drop you cant get with neuspeed is the race spring drop.
ive had them for over 2 years and theyre working great.
philly91crx
Suspension & Brakes
Mar 8, 2008 06:31 PM
mexinug
25
Apr 16, 2007 10:08 AM
VisualAutoMotoring
Oct 28, 2005 11:18 AM
kevino002
Suspension & Brakes
Feb 27, 2005 06:30 PM
aznfab
Oct 3, 2003 06:15 PM
