Minimum reqirements for the 5 lug conversion.
Old Jul 25, 2004 | 10:57 AM
campbuds's Avatar
Default Minimum reqirements for the 5 lug conversion.
OK... I thoroughly read each and every thread that mentions a 5 lug conversion and not one lists the minimum requirements to perform it.
I don't want the suspension or brakes if they are not necessary. I am just doing it to have the 5 lug for the ITR gun metal rims.
Can anyone help me out???
campbuds's Avatar
Default Re: Minimum reqirements for the 5 lug conversion. (campbuds)
Old Jul 25, 2004 | 12:02 PM
.M.'s Avatar
.M.
bizzump.. i'd like to know as well... i want white type r rims!
Old Jul 25, 2004 | 12:11 PM
Andyb22g's Avatar
well your going to have to get the brakes for sure and you will need the 5 lug hubs, im not sure what else you will need
Old Aug 7, 2004 | 12:13 AM
Mikizzle's Avatar
I was told you can jsut get the type-r hub and bearings and put em on. But dont know waht kind of calipers to use with the rotors. Bump would like to know how to do this.
Old Aug 7, 2004 | 03:27 AM
campbuds's Avatar
Default Re: (grn4drgsr)
OK well I have since found out what is the minimum amount of parts required to do this is. But basically you can't just replace a hub because of the difference in the sizes of the front and rear brakes. Here is a list of what parts are necessary:
Front knuckle w/ hub
Caliper and rotor
Rear knuckle (trailing arm)
hub
Caliper and rotor.
Modified by campbuds at 3:19 PM 8/7/2004
Old Aug 7, 2004 | 04:07 AM
.M.'s Avatar
.M.
Default Re: (campbuds)
thx! how much would the minimum req. cost?
Old Aug 7, 2004 | 06:18 AM
campbuds's Avatar
Default Re: (JH4DC4)
There is a guy on here that can get it for $1200. But you still need rims.
Old Aug 7, 2004 | 06:24 AM
latindc2's Avatar
Who that guy?
http://store.yahoo.com/twincam....html
Inlinefour has it for 1,800
Old Aug 7, 2004 | 07:48 AM
campbuds's Avatar
Default Re: (latindc2)
can't say i remember
Old Aug 7, 2004 | 08:13 AM
SilverDc2's Avatar
if you just need the 5lug...just get the hub's and re drill your rotors to 5lug...it will work....trailing arms are the same, i would recommend to buy the whole thing though..
Old Aug 7, 2004 | 08:25 AM
campbuds's Avatar
Default Re: (SilverDc2)
i can't imagine redrilling rotors would be reliable.
OGI8UUP
May 2, 2023 10:03 AM
Dcsports92
Feb 27, 2008 05:20 PM
hellogsr
Jun 5, 2006 06:39 PM
WagOvan Man
Feb 28, 2006 02:00 PM
92vx6
Nov 20, 2004 09:06 AM
