ABS Problem?
Old Feb 2, 2005 | 02:35 PM
r3v da t3g's Avatar
Default ABS Problem?
Its a 94' LS and everytime i start the car the ABS makes a noise for a bit then stops and when it stops the ABS on my gauge glows...... anyone have any idea?
*When i say ABS makes a noise its the component in the engine not the brakes or rotors*
Old Feb 4, 2005 | 07:36 PM
TypeRCrazy05''s Avatar
Default Re: ABS Problem? (r3v da t3g)
Whats up everybody i seem to be having this problem too any ideas??.....
Old Feb 4, 2005 | 08:18 PM
timmy8151's Avatar
Default Re: ABS Problem? (TypeRCrazy05')
I have the same problem. The sound you're hearing is the ABS modulator trying to pressurize itself. This is a common problem in 94-95 integras due to the design of the system.
First thing you should do is pull your error code. Use this thread as a reference: https://honda-tech.com/zerothread?id=978933
You're most likely going to pull the following codes:
18- high pressure system
13-high pressure leakage
If you go to a shop they're going to want to replace the modulator, but that's gonna cost about $1000 with labor. However, a common fix for the system leak is replacing a $2 seal at the accumulator.
It's part # 23: 57072-ST5-003 O-RING (P5) 1.20
Old Feb 5, 2005 | 05:48 AM
IntegraLs94Cam's Avatar
Default Re: ABS Problem? (timmy8151)
i have the same problem i pulled my code and it was only a left rear sensery thing... i douno how to fix it ... does that cost alot to do ?
Old Feb 5, 2005 | 10:09 AM
DarkTeg94's Avatar
Default Re: ABS Problem? (IntegraLs94Cam)
For that rear sensory thingy, it's your let rear wheel sensor. It's easy. Took me a hour or less. Now my ABS works
Old Feb 5, 2005 | 11:33 AM
Irish Integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem i pulled my code and it was only a left rear sensery thing... i douno how to fix it ... does that cost alot to do ?</TD></TR></TABLE>
try taking out the sensor and cleaning it before you replac it, they gather road dirt over the years. you'll see it on the back of the hub, its a wire going into a sort of cylindrical shaped thing with a 10mm bolt holding it in. use a bit of brake or carb cleaner and a rag...or WD40. Good luck
Old Feb 5, 2005 | 08:11 PM
Default Re: ABS Problem? (Irish Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irish Integra &raquo;</TD></TR><TR><TD CLASS="quote">
try taking out the sensor and cleaning it before you replac it, they gather road dirt over the years. you'll see it on the back of the hub, its a wire going into a sort of cylindrical shaped thing with a 10mm bolt holding it in. use a bit of brake or carb cleaner and a rag...or WD40. Good luck</TD></TR></TABLE>
So you dont have to take off your rotors off to replace it?
Old Feb 5, 2005 | 11:26 PM
Bk2fwd's Avatar
i get the pressurizing sound, but no abs light or cel. you guys think my abs took a ****?
is there any war to completely remove the abs system?
Old Feb 6, 2005 | 01:06 AM
billyhoe's Avatar
Default Re: (Bk2fwd)
the noise i wouldnt worry bout but you should definitely check and see wat abs code you are pulling
Old Feb 6, 2005 | 07:40 AM
numba1's Avatar
PM'd you.
Old Feb 6, 2005 | 02:32 PM
ctownintegra's Avatar
My light has been on forever and I always hear the motor pump for about 2-3 seconds every 10 minutes or so. How hard is that $2 seal. My code is high pressure system. and the lines are not leaking.
Old Feb 7, 2005 | 11:40 AM
So you dont have to take off your rotors off to replace it?</TD></TR></TABLE>
As far as I know, no, it would be very unusual to have to take them off just for an ABS sensor, can't say I've ever had to.
Old Feb 7, 2005 | 11:50 AM
As far as I know, no, it would be very unusual to have to take them off just for an ABS sensor, can't say I've ever had to.</TD></TR></TABLE>
if i jack up my car where should i look to find this sencery... for some reason my abs light went away and my abs did not make nosie but came back on later that day ... damn teg.... make up ur mind!!!
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">So you dont have to take off your rotors off to replace it?</TD></TR></TABLE>Gotta take the rotors off to see the sensor & toothed wheel, also to measure clearance between these.
Maybe(?) you can change the sensor from the inboard side of the brakes. But as easy as it is to take off the rotor, why not do that & have a look?
Old Feb 7, 2005 | 01:40 PM
95lstegman's Avatar
Default Re: ABS Problem? (JimBlake)
mine used to bzzz for several seconds on startup, and then the ABS light would come on in the dash. sometimes the light didn't come on, but the light would sometimes go on or off during a longer drive, and after almost every drive it would switch (if it was on for the last drive, it will be off the next one). i found a replacement from a '96 canadian market integra, and it took about 45 mintues to replace. never ever had the light come on again, except right around startup when it comes on for a system check. in fact, i can SLAM the brake pedal at about 45mph in a pouring rain and not lock up and not have ABS come on. decent tires, i guess. stops great dry, too. hurts, almost.
Old Feb 7, 2005 | 01:41 PM
95lstegman's Avatar
Default Re: ABS Problem? (95lstegman)
oh yeah, the used unit from Canada cost about $55 shipped. worth every penny.
Old Feb 7, 2005 | 03:17 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem. The sound you're hearing is the ABS modulator trying to pressurize itself. This is a common problem in 94-95 integras due to the design of the system.
It's part # 23: 57072-ST5-003 O-RING (P5) 1.20 </TD></TR></TABLE>
any idea how hard this is to fix?
Old Feb 7, 2005 | 03:21 PM
mslate's Avatar
Timmy, If that seal is bad will I see fluid leaking externaly?
Old Feb 7, 2005 | 03:46 PM
95LSDOHC's Avatar
Default Re: ABS Problem? (mslate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mslate &raquo;</TD></TR><TR><TD CLASS="quote">Timmy, If that seal is bad will I see fluid leaking externaly?</TD></TR></TABLE>
I have the same noise/light problem....and sometimes i see fluids near my abs stuff....would that mean that gasket is shot??
Old Feb 7, 2005 | 04:43 PM
timmy8151's Avatar
Default Re: ABS Problem? (b cruz)
Yes, you should see some fluid at the base of the modulator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz &raquo;</TD></TR><TR><TD CLASS="quote">any idea how hard this is to fix?</TD></TR></TABLE>
Not that hard at all. Here are some instructions that BSQ sent me:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ &raquo;</TD></TR><TR><TD CLASS="quote">You will need to disconnect the electric socket to the ABS module, then disconnect the brake lines that connect to it. After this has been done you should be able to unbolt the ABS module from the bracket. Once the ABS module is out of the car, you will be able to unbolt the ABS accumuluator and replace the O-ring. Reinstall the ABS module in the reverse order. You will then just need to bleed the brake lines and the ABS system.</TD></TR></TABLE>
Old Feb 8, 2005 | 07:23 AM
B_CRUZ!'s Avatar
thanks!
Old Feb 8, 2005 | 09:10 AM
ALF's Avatar
ALF
I had the same exact problem. I found out I had no brake fluid in the ABS unit, so I refilled it. This didn't make the ABS light go away so I rode around like this for a while, until I reset my computer this weekend. Now the problem is completely gone.
Old Feb 9, 2005 | 12:52 PM
SpoonREVS's Avatar
Default Re: ABS Problem? (ALF)
IM having the same problem does any know where i can i find this seal or what is the name of this O ring?
Old Feb 9, 2005 | 12:55 PM
r3v da t3g's Avatar
Default Re: ABS Problem? (SpoonREVS)
Yea good quesiton spoon..... whats the name of the o ring? and where is it? i can see it in the diagram but cant really locate in the car any help would be greatful thanks to all who helps and thanks in advance for those who will help is it 57072-ST5-003 O-RING (P5) 1.20 ????
Old Feb 10, 2005 | 03:32 AM
JimBlake's Avatar
for Spoon & r3v...
That whole ABS unit is behind the right headlight, alongside the air cleaner. The pressure accumulator is the vertical can (#2). It's bolted in from below, so that's why you gotta take stuff out to get at the bolts (#4).
Make sure you relieve the pressure first, before trying to take that apart.
ALF...
You should probably bleed your ABS. I bet just running it didn't get all the air out.
