CTR cam question(searched)
Old Feb 2, 2005 | 03:48 PM
gsr-2nr's Avatar
Default CTR cam question(searched)
i searched and didnt find exactly what i was looking for so for those who put the ctr cams in ur gsr i have a question. ive looked at several websites that outline the install process but they all differ. so is it necessary that i reset the timing, and mess with teh t belt tensioner cause some list it and some dont. also i just got a valve adjustment in dec should i have it done after i put them in.
Old Feb 2, 2005 | 03:56 PM
rough_draft's Avatar
http://www.c-speedracing.com/h...m.php
just go by that and you will be fine good luck
triple_s1x's Avatar
Default Re: CTR cam question(searched) (gsr-2nr)
Swaping cams is going to require you to loosen up the tensionor and reset the belt. I would also do the valve lash again with the different cams.
Old Feb 2, 2005 | 04:16 PM
2G0S0R1's Avatar
New User
Default Re: CTR cam question(searched) (triple_s1x)
Unless you are replacing the timing belt, it is not necessary to adjust the tensioner. When I installed my cams and valvesprings, I just slipped the cam with the gear attached back under the belt... positioned it, and put the cam caps back on. Has been working like a charm for like 20k.
Old Feb 2, 2005 | 04:37 PM
gsr-2nr's Avatar
Default Re: CTR cam question(searched) (2G0S0R1)
all good to know, what about messin with the timing is that necessary
Old Feb 2, 2005 | 05:49 PM
triple_s1x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">Unless you are replacing the timing belt, it is not necessary to adjust the tensioner. When I installed my cams and valvesprings, I just slipped the cam with the gear attached back under the belt... positioned it, and put the cam caps back on. Has been working like a charm for like 20k.</TD></TR></TABLE>
Well you can do it that way also, just becareful and make sure the engine is at TDC and the the cam gears say UP
vttitan18
Jun 5, 2008 05:22 AM
SrT4u2nV
May 23, 2006 03:55 AM
AK94GSR
Feb 11, 2004 10:03 AM
96tegsr
Jul 20, 2003 01:06 PM
2fknlo
Apr 1, 2002 06:40 AM
