Seats.....
Old Feb 3, 2005 | 02:00 PM
Team Underground Teg's Avatar
Default Seats.....
Hey,
I am planning on buying a pair of Tom Motorsport Bride (knockoff) seats and I wanted to know where I am supposed to mount the female end of the seat belt. Also what should I use to mount the seats to the floor. They come with sliders but I am not too sure what to do for feet. Anyway any info/pics you can give would be awsome. Thanks,
Ben
Old Feb 3, 2005 | 03:05 PM
SMZ GSR's Avatar
Default Re: Seats..... (Team Underground Teg)
I wouldn't use the sliders that the seats come with. They're very shitty in quality. I ended up buying Sparco sliders and brackets to put them in my 98 2dr. The Sparco bracket has a tab on it where you will mount the stock seatbelt or a harness.
But to get the Sparco parts to work I had to drill a couple new holes.
Old Feb 3, 2005 | 03:33 PM
Gekko's Avatar
Default Re: Seats..... (SMZ GSR)
I bought some knock off seats and had to get WeaponR brackets to mount them. Used the sliders that came with the seats, cheap but they work fine. I made a custom mount for the seatbelts because the aftermarket brackets held them too close to the e-brake console.
Old Feb 3, 2005 | 03:34 PM
Thanks for the info. Do you have some pics of where you mounted the belt? Just as I want to get an idea of what I will need to do. And also if you have the part # handy that would be awsome. Thanks,
Ben
Old Feb 4, 2005 | 07:13 AM
Bump
Old Feb 4, 2005 | 07:51 AM
da'ee's Avatar
Default Re: (Team Underground Teg)
keep it bumpin
Old Feb 4, 2005 | 09:31 AM
Gekko's Avatar
Default Re: Seats..... (Gekko)
Sorry, I don't have any pics right now. I drive a DA so the part number would be different than yours, I'm assuming you have a G3?
Old Feb 4, 2005 | 11:47 AM
^^^Yeah. I checked out Sparco's website though and I believe I found the right thing. Is it the flat mount kit with sliders?
Old Feb 4, 2005 | 12:06 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't use the sliders that the seats come with. They're very shitty in quality. I ended up buying Sparco sliders and brackets to put them in my 98 2dr. The Sparco bracket has a tab on it where you will mount the stock seatbelt or a harness.</TD></TR></TABLE>
I believe this is incorrect. I don't think Sparco has any sort of seat rail that has an attachment for the stock seatbelt (at least not for any Honda). The only company that does this right now (outside of custom made ones) is called Wedge. Sparco distributes this Wedge bracket, so some people think it is Sparco when it is not.
Wedge has a piece on the rail where it sticks up where you can bolt your female end of the belt. Sparco does not.
Old Feb 4, 2005 | 12:18 PM
SMZ GSR's Avatar
Default Re: Seats..... (shamoo)
Well, I ordered a pair of Sparco brackets and they have the tabs. 2 people I know with WRX's had Sparco brackets with tabs and an ITR owner has twin Sparco seats with brackets that have tabs . It's just a metal piece with a hole. Use any bolt and washer to hold the buckle to it.
Old Feb 4, 2005 | 12:20 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">Well, I ordered a pair of Sparco brackets and they have the tabs. 2 people I know with WRX's had Sparco brackets with tabs and an ITR owner has twin Sparco seats with brackets that have tabs . It's just a metal piece with a hole. Use any bolt and washer to hold the buckle to it.</TD></TR></TABLE>
Weird.
Just FYI: The Wedge brackets that Sparco sells have a Sparco sticker on them.
Old Feb 4, 2005 | 12:27 PM
SMZ GSR's Avatar
Then there is a good chance that they are Wedge. But since I got them as Sparco, I'll call them that lol
Old Feb 4, 2005 | 06:24 PM
Gekko's Avatar
I contacted Sparco a while back and their brackets have spots to mount the stock belts. Weapon R does also, as well as some others. I'm not sure about corbeau though.
Old Feb 5, 2005 | 05:54 AM
^^^Thanks for the info guys.
nick_nrg
15
May 4, 2019 11:15 PM
P0411
Apr 21, 2019 06:43 PM
puregroove
Jan 29, 2005 07:05 PM
B18C_eg
Feb 26, 2004 10:07 PM
