Cable tranny code ?
Old Feb 2, 2005 | 10:22 AM
HPDE007's Avatar
Default Cable tranny code ?
I didn't know where else to post this question. I have a few cable trannys in my garage: I have a S1, a Y1, and a I just got an A1. My question is does anyone know what gear ratios the A1 has, or which tranny it is? Any help on this would be greatly appreciated.
Old Feb 2, 2005 | 12:10 PM
HPDE007's Avatar
Default Re: Cable tranny code ? (HPDE007)
Does anyone Know?
Old Feb 2, 2005 | 12:21 PM
b62pteg#2's Avatar
http://www.allmotorhonda.com/t...s.htm
or
http://www.geocities.com/Motor...s.htm
That's a start, HTH.
-- Kevin
Old Feb 2, 2005 | 12:30 PM
HPDE007's Avatar
Default Re: Cable tranny code ? (b62pteg#2)
b62pteg#2
I looked at http://www.knology.net/~jedikl...s.htm before I posted this. I think this is a European transmission, and have been told that it is the same as the Y1 tranny I just want to know for sure.
Thanks for the info though.
Old Feb 2, 2005 | 12:37 PM
HONDA_TYPE_R's Avatar
S1/J1 JDM B16A X-Si 3.230 2.105 1.458 1.107 0.848 3.000 4.400
Y1; Y1 w/LSD JDM B16A SiR I 3.166 2.052 1.416 1.103 0.870 3.000 4.266
S4C/Y21 USDM B16A2, B16A3; JDM SiR2, JDM SiR2 w/LSD 3.230 2.105 1.458 1.107 0.848 3.000 4.400
Y80/S80 JDM B16B w/LSD; JDM B18C 96-spec R w/LSD 3.230 2.105 1.458 1.107 0.848 3.000 4.400
YS1 USDM B17A1; JDM B16A X-Si w/LSD 3.307 2.105 1.458 1.107 0.848 3.000 4.400
S1/YS1/A1 USDM B18A 3.166 1.857 1.259 0.935 0.742 3.000 4.400
Y80/S80 B18B 3.230 1.900 1.269 0.966 0.714 3.000 4.266
?? B18B (auto) 2.722 1.468 0.975 0.638 ---- 1.954 4.357
S80/Y80; S80 w/LSD, Y80 w/LSD JDM B18C SiR-G 3.230 1.900 1.360 1.034 0.787 3.000 4.400
S80 w/LSD JDM B18C Spec-R 3.230 2.105 1.458 1.034 0.787 3.000 4.785
Y80 USDM B18C1 3.230 1.900 1.360 1.034 0.787 3.000 4.400
S80 w/LSD USDM B18C5 3.230 2.105 1.458 1.107 0.848 3.000 4.400
S80 w/LSD EDM B18C Spec-R 3.230 2.105 1.458 1.034 0.787 3.000 4.785
I got this from http://www.hondaswap.com in the reference materials section. Credit goes to them. The YS1 is actually only in the 92-93 Integra. 90-91 Integra's had the S1 and A1 trannies. I also think the final drive number is 4.266 on those, but I am not TOTALLY sure. Willing to sell your Y1???
Old Feb 2, 2005 | 01:49 PM
HPDE007's Avatar
Default Re: Cable tranny code ? (HONDA_TYPE_R)
How do you tell the difference between the USDM S1 and the JDM S1? Thanks for the info I really appreciate it. I need the Y1 Trans otherwise I would sell it, sorry.
Old Feb 2, 2005 | 03:01 PM
HPDE007's Avatar
Does anyone know how to tell the difference between the USDM S1 and the JDM S1?
Old Feb 2, 2005 | 04:53 PM
HPDE007's Avatar
Bump
Old Feb 2, 2005 | 05:19 PM
gen2moredoors's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HPDE007 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know how to tell the difference between the USDM S1 and the JDM S1?</TD></TR></TABLE>
i believe the only way to tell is to drive it and check the rpm's / speed. or cound the teeth on the gears...i think they have a diff count
Old Feb 2, 2005 | 07:47 PM
Default Re: Cable tranny code ? (gen2moredoors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2moredoors &raquo;</TD></TR><TR><TD CLASS="quote">
i believe the only way to tell is to drive it and check the rpm's / speed. or cound the teeth on the gears...i think they have a diff count</TD></TR></TABLE>
Pretty much. The final drive is lower on the USDM compared to the JDM...crack open the case and count the teeth on the final drive maybe?
JDMTOKER
Mar 3, 2009 09:33 AM
Richyrich1988
Oct 7, 2008 01:08 PM
integrawow
Mar 5, 2008 02:21 PM
B18C1_CRX
26
Feb 10, 2004 07:48 AM
charjacq
Nov 8, 2002 05:12 AM
