need help!
Old Feb 2, 2005 | 10:02 AM
halozero's Avatar
Default need help!
just bought a teg last tuesday.
i'm getting 2 codes out of the CEL.
8 TDC - top dead centre sensor
23 - knock sensor
not sure what i'm supposed to do with these or if my car is at risk.
any help would be appreciated.
Old Feb 2, 2005 | 05:31 PM
halozero's Avatar
Default Re: need help! (halozero)
Old Feb 2, 2005 | 06:52 PM
Dropped90Integra's Avatar
Well I never heard of the #8 code myself, I'd say check out your knock sensor first, maybe thats messing up the other one.... maybe someone else knows better... free bump, Good Luck
Old Feb 3, 2005 | 12:33 AM
halozero's Avatar
Default Re: need help! (SlammedDAHatch)
knock sensor is nothing to worried about i'm told..
the other means my pistons are being fully extended... which is not good i'm told but it's nothing to worry about as long as i treat her nicely...
would just like some other opinions..
Old Feb 3, 2005 | 11:34 AM
halozero's Avatar
ttt
Old Feb 3, 2005 | 11:56 AM
Honda Hick's Avatar
RS's had knock sensors? I thought only VTEC motors had them.
Old Feb 3, 2005 | 01:02 PM
LSvtec03's Avatar
Default Re: need help! (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">RS's had knock sensors? I thought only VTEC motors had them. </TD></TR></TABLE>
ditto
Old Feb 3, 2005 | 03:20 PM
halozero's Avatar
Default Re: need help! (LSvtec03)
b16a sir ii swap.
Old Feb 5, 2005 | 12:12 AM
halozero's Avatar
bump
Old Feb 5, 2005 | 01:20 PM
allmotorjdism's Avatar
On the knock sensor in my b18c was loose causing it to rattle and tell the ecu the motor was knocking (i guess). Tighten it up and see what happens, i think its a 27mm deep-wheel socket. Mabye your timing is off..causing the code 8...worth a try.
Old Feb 6, 2005 | 02:15 AM
billyhoe's Avatar
Default Re: need help! (allmotorjdism)
TDC = bad sensor inside distributor or just timing is way off
Old Feb 6, 2005 | 02:19 AM
billyhoe's Avatar
Default Re: need help! (billyhoe)
replace dist. that should take care of the tdc code, as for knock sensor code. your car is an rs it shouldnt pull a KS code unless you are running a vtec ecu but if that were the case u would also get code 22 vtec pressure switch. check again two slow blinks and 3 fast blinks.........get some1 else to look at it also
Old Feb 6, 2005 | 02:37 AM
halozero's Avatar
p30 ecu
b16a sir ii swap.
shoklid
Sep 6, 2009 04:58 PM
Black_Rex
Jan 23, 2006 03:27 PM
carraway99
Feb 17, 2005 10:29 PM
b18cEF9
Dec 20, 2004 04:22 PM
smslude
Jan 14, 2003 10:37 PM
