beaks instructions
Old Feb 3, 2005 | 08:06 PM
intougera's Avatar
Default beaks instructions
hey guys i just got the beaks subframe kit for my dc, with no instructions. i tried downloading them off of the beaks site with no luck. anyone have instructions or know where i could find em'. thanks
Old Feb 3, 2005 | 08:15 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: beaks instructions (intougera)
It's very similar to installing the BSQ kit so just follow these instructions:
http://geocities.com/bretq/swaybar_install.html
If you dont know how the parts go together...Here:
VS
BSQ
Old Feb 3, 2005 | 08:21 PM
intougera's Avatar
no other holes need to be drilled?, btw thanks for the quick response
Old Feb 3, 2005 | 08:24 PM
In-N-Out Burger
Sorry, I gave you the wrong link...
Here:
I edited my original post and put the correct link there also.
p.S. Here it is in PDF format:
http://www.geocities.com/bretq...n.pdf
Old Feb 3, 2005 | 09:11 PM
dt4life's Avatar
I just did that install about 2 weeks ago and I actually had to shave the beaks braket that goes within the subframe so it'd clear the LCA. Finally worked though
Old Feb 3, 2005 | 09:12 PM
99IntegraGS's Avatar
I have a Word document with some Beaks install instructions that I must have saved from a post on some message board or from someone's website. I'll link it from my machine below...
http://theterritory.servebeer.com/BEAKS/
Not real detailed, but it does include some pics.
JD
Old Feb 4, 2005 | 05:16 AM
BSQ's Avatar
BSQ
Default Re: beaks instructions (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">It's very similar to installing the BSQ kit so just follow these instructions:
You can use my BSQ installation instructions when using the Beaks kit. The only difference is, you will need to remove 4 additional tacked-welded nuts from the back-side of the subframe. There are 2 on each side that were used for the original swaybar. You will also need to either remove or modify the ABS sensor wire bracket.
Also, if you get the dreaded "exceeded bandwidth" message on my website, you can try my mirror site at http://geocities.com/bretq2/swaybar_install.html .
Consistent1
Aug 5, 2005 07:56 AM
pearlteg
Apr 21, 2004 04:46 PM
SD_EM1
Audio / Security / Video
Mar 26, 2003 08:12 PM
ITRfaithful
Jul 2, 2002 12:59 AM
240sxtc
Jun 7, 2002 01:21 PM
