Compression on a GSR
Old Feb 1, 2005 | 12:59 AM
greentrbo95gst's Avatar
Default Compression on a GSR
Hey i was wondering if any of you guys know what the compression is on a stock b18c. I am not asking for the ratio, but for the actual psi #'s. Thanks for help
Old Feb 1, 2005 | 03:45 AM
BDBGoalie1982's Avatar
Default Re: Compression on a GSR (greentrbo95gst)
don't remeber exact numbers, bt as long as there is no more than 10% variance between the numbers you're fine
Old Feb 1, 2005 | 04:58 AM
JimBlake's Avatar
200 is kinda sorta typical.
It depends on the gauge. How much volume is inside the gauge & where the check valve is located. That's why you shouldn't really compare numbers with someone else unless EVERYTHING is the same. (Also oil temperature & viscosity, starter rpm, etc...)
Old Feb 1, 2005 | 08:39 AM
n0 iNTegRiTY's Avatar
I want to say 240, but I can't guarantee it.
B18C-YA!
Jan 14, 2008 02:07 AM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
cu3tip
Mar 14, 2004 09:03 PM
Petah
Aug 19, 2003 11:37 PM
Nameless RB26
Apr 10, 2003 01:53 PM
