Headlight Aim?
Old Feb 3, 2005 | 12:45 PM
spoonfed95's Avatar
Default Headlight Aim?
I have seen lately integras rolling around with there high beams on and aimed like there low beams. They aren't blinding because the have adjusted the high beams to act like the low beams. Anyone else seen this yet? Interesting but I think theres a better way for more light.
Old Feb 3, 2005 | 01:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Headlight Aim? (spoonfed95)
Maybe you are seeing Integras with daytime running lights, which runs the high beams at low voltage? You can't adjust the high beams low enough to not blind everybody, because there is no cutoff shield of any kind in there, it just throws the light out all over the place, up, down, sideways, etc.
Using a 9005 high beam bulb in the low beam projector would be a much better way to get more light, and you would still be using the projector with the cutoff beam, so it won't blind anybody.
Old Feb 3, 2005 | 01:19 PM
TunerN00b's Avatar
You'll never get the high beams adjusted to not blind, they don't have the cutoff that the low beam does. They're not just brighter, the reflector is shaped to throw light in all forward directions, even up. Not to mention its completely illegal to drive around with high beams on in traffic.
Also, 4 headlights won't benefit. You'll have more light up close (where you don't need it) and no more farther away (where you do). Just put that high beam bulb in the low beam socket, brighter light, and a perfect cutoff.
So, if you want more light, 9005 conversion, or retro some nice HID projectors in.
Old Feb 3, 2005 | 01:23 PM
Gerbilo's Avatar
Default Re: Headlight Aim? (TunerN00b)
The 9005 Conversion rocks!
Check my sig for the HowTo that I made a few months back.
Patrick knows it rocks
Old Feb 3, 2005 | 02:45 PM
spoonfed95's Avatar
Default Re: Headlight Aim? (Gerbilo)
Well first, this is not for me as I have already gone to HID. I was just wondering if anyone has seen this before. It may have been daytime running lights, I am not sure just wondering if anyone had seen this before.
Old Feb 3, 2005 | 04:46 PM
Taristin's Avatar
I've seen tegs on at night with only the highs, and wasn't blinded by them. But I assumed they were DRLs... Dunno.
Old Feb 4, 2005 | 09:09 PM
calxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">You'll never get the high beams adjusted to not blind, they don't have the cutoff that the low beam does. They're not just brighter, the reflector is shaped to throw light in all forward directions, even up. Not to mention its completely illegal to drive around with high beams on in traffic.
So, if you want more light, 9005 conversion, or retro some nice HID projectors in.</TD></TR></TABLE>
Wow, you repeated everything that Patrick posted.
Old Feb 13, 2006 | 07:56 PM
HomeDepotMade's Avatar
Default Re: Headlight Aim? (calxtreme)
i did the same with the high to low beam conversion. its brighter and looks great. I also replace my high beam light bulbs to super yellow ones, to give it a fog lights look. it looks awsome and you get great visibility.
James_Starks
21
Oct 16, 2022 12:23 PM
1991civicd16z6
14
Jan 15, 2008 09:01 PM
inane
11
Oct 25, 2004 06:40 PM
tekstyle
Aug 18, 2004 02:04 PM
weakGOODJunKieS.com
Mar 21, 2003 02:08 PM
