Ecu question
Old Feb 1, 2005 | 12:22 AM
JFG Kevin's Avatar
Default Ecu question
arite, i have a p28 with a mugen chip in it. I put it in my car to test it out and it ran fine. i took it out again because it was using up too much gas. i put bak my p72 check to save some gas, but then i put back the p28 again cause i got bored, when i put back the p28 i pulled a check engine like which was (21) vtec not workin. I put bak my p72 and it didn't pull a check engine light. What could be wrong with the ecu?
Old Feb 1, 2005 | 12:26 AM
iH8RICERZ's Avatar
Default Re: Ecu question (aznstyler119)
did you make sure all your plugs were totally pushed/plugged in?
Old Feb 1, 2005 | 12:28 AM
JFG Kevin's Avatar
Default Re: Ecu question (iH8RICERZ)
yes...i did it two times..bak and forth from the p28 to the p72...the p72 alway worked fine but p28 pulled a code.
Lou845
Engine Management and Tuning
25
Jul 10, 2012 10:01 AM
Art701
May 19, 2011 12:15 AM
undagroundrican
Jan 22, 2005 10:23 PM
InspiredRacer
Mar 7, 2004 08:14 AM
