integ 2000: change automatic transmission filter and fluid
Hi Guys,
How often should be change the automatic transmission filter and fluid? Is it necessary to do it often? What do you guys recommend?
Thanks,
AG
Thanks,
AG
Re: integ 2000: change automatic transmission filter and fluid (azncollegeguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azncollegeguy »</TD></TR><TR><TD CLASS="quote">Hi Guys,
Thanks,
AG</TD></TR></TABLE>
Can't change the filter, since there's no pan to drop. I recommend drain and refilling your ATF every 15k-20k miles. Also, only use Honda ATF, because of the Z1 additive it contains.
If you've never changed your ATF or aren't sure how many miles are on the current fluid, I'd suggest you do a triple flush. Just drain and refill your ATF 3-4 times, making sure to drive a little between each change.
Thanks,
Re: integ 2000: change automatic transmission filter and fluid (timmy8151)
Wow thanks for the input.
Sorry, im a software guy, do you know have any specific instruction? Is there a nut underneath the teg to loosen?
Thanks alot!
AG
Thanks alot!
AG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azncollegeguy »</TD></TR><TR><TD CLASS="quote">Wow thanks for the input.
Thanks alot!
Yes, just remove the drain bolt and let the old fluid drain out. Put back on the bolt. Then you need to pull out the AT dipstick which is on the passenger side behid the Intake arm (it has a yellow top). Get a long narrow funnel that fits into the hole. Put in 3 qts of Honda ATF, then put back in the dipstick. Start the car and from D1 up to D4, cycle through the gears. Turn off the engine, and pull the dipstick to check the fluid level.
Thanks alot!
wow perfect that is exactly what i need, thanks a bunch.
How many of you guys out there flush your ATF ??
How important is it? Does it simply help with smoother shifting?
Thanks,
AG
Thanks,
AG
i've only flushed once when i bought the car. it's very important because if you don't change it, there will be a gunk of metal on da drain plug. it kind of smooth shifting.
dk199160
10-23-2015 11:54 AM
theLemur
12-27-2014 01:01 PM
P-M-B,93EXsedan
32
03-28-2014 04:29 PM
