gsr problems
Old Feb 24, 2005 | 05:12 PM
phantom grey eg's Avatar
Default gsr problems
after installing a new fuel filter, plugs wires, cap, and rotor i started the car and when i hit the gas it studders for a few seconds then goes, it does not have the power it did either, any idea what this might be?
Old Feb 24, 2005 | 05:16 PM
Spoon ITR's Avatar
Default Re: gsr problems (phantom grey eg)
Are all of the wires coming off of the cap going to the right plugs maybe???
Old Feb 24, 2005 | 05:17 PM
Default Re: gsr problems (JDMDC2GSR)
yes they are
Old Feb 24, 2005 | 05:31 PM
blkb18's Avatar
did you remove the distributor, maybe to get the rotor screw out? If so your timing may be off.
Old Feb 24, 2005 | 05:33 PM
chero112's Avatar
Default Re: gsr problems (blkb18)
Your timing might be off........
Old Feb 24, 2005 | 05:34 PM
yes, when i took the cap off i could not get the rotor screw out unless i turned it over till the screw was were the opening is to get it off, that should not **** up the timing tho because timming is done with the timing belt and that was not fucked with correct?
Old Feb 24, 2005 | 05:40 PM
blkb18's Avatar
we are talking ignition timing, the distributor can be adjusted by loosening the bolts and turning it, but to do so you have to jump your diagnostic plug above your ecu, and you also need a timing light. Or if you are lucky you may be able to see where the bolts were before on the distributor, just set it there.
Old Feb 24, 2005 | 05:43 PM
i didnt **** with those settings, and it ran fine before, its only since i changed that ****
Old Feb 24, 2005 | 05:47 PM
blkb18's Avatar
did you just put the distributor back in, or were you carefull to put it back in EXACTLY how it was before, 1/4 inch turn either way will throw your igition timing off 10, 15 maybe 20 degrees.
Old Feb 24, 2005 | 06:18 PM
never took my distributer off, i put the cap and rotor on, with the distrubuter on the car
meallout
Mar 19, 2009 11:34 AM
4gCRX
Oct 31, 2004 04:19 PM
Agent Daimon
Dec 19, 2002 09:46 PM
