Header Question
Old Feb 23, 2005 | 04:56 PM
GSRerrr's Avatar
Default Header Question
I just got my Comptech header and was wondering what tools i would need to install it? like torque wrench and other stuff.. sorry noob question but my first time installin myself thanks.
o yea sorry i have a 2000 GSR thanks again
Old Feb 23, 2005 | 05:15 PM
purplegsr's Avatar
Default Re: Header Question (GSRerrr)
http://www.c-speedracing.com/h...r.php
See the how-to above, but off the top of my head: jack, jackstands, 14mm socket, 12mm socket, o2 socket (they have a hole for the wires to go through, so you don't have to unclip it), socket wrench, 12mm closed end wrench, torque wrench is optional - but be gentle on those bolts, anti-sieze lubricant for the threads on the o2, maybe a new header gasket from the dealer.
Old Feb 23, 2005 | 05:18 PM
apok's Avatar
You'll need:
impact gun to break the bolts between header and cat (unless you're superman).
12" socket
12" wrench
adjustable wrench or o2 sensor tool (o2 sensor)
14" wrench (to hold the other side of the bolt between header and cat on the back)
That should be all.
Old Feb 23, 2005 | 05:24 PM
5 Speed AP2's Avatar
Default Re: Header Question (apok)
Damn straight! Gorilla strength needed.
Old Feb 23, 2005 | 05:25 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apok &raquo;</TD></TR><TR><TD CLASS="quote">You'll need:
Very true, if you don't have an impact, soak the bolts in PB Blaster the night before and have a large breaker bar - I have had good luck with that method, but I have also had bad luck when I dropped the breaker bar on my head and started bleeding.
Old Feb 23, 2005 | 05:28 PM
apok's Avatar
Default Re: Header Question (purplegsr (Exospeed))
Yea, I got bloody fingers from using the cheater method (link 2 wrenches together and push with all your might to break). It just slipped off the corners of the nut and I was feeling pain for a few minutes.
It would be worth it to take your car to a friend with an air tool set. If you don't know anyone, pay an independant mechanic like 5 bucks and have him break it for you, then drive home and enjoy the sound of open header for a few minutes before you install the header yourself.
Old Feb 23, 2005 | 06:40 PM
GSRerrr's Avatar
thanks everyone
Old Feb 23, 2005 | 06:47 PM
GSRerrr's Avatar
is there anyways to actually screw up? or is everything straight forward? the only ything im worried about is the o2 sensor thing, thanks
up
Old Feb 23, 2005 | 09:05 PM
purplegsr's Avatar
You can screw up. Be careful with the o2 sensor, don't mess up the wires, and don't get anti-sieze on the sensor part. Also, make sure you reuse the stock doughnut gasket that goes between the header and cat. Lastly, when you torque the header bolts, do it from inside-out and do it in steps before torqueing it down all the way. It's also pretty hard to maneuver the one piece header into the engine bay, so be careful and be willing to loosen up the fan and radiator hoses.
khenning
Sep 9, 2010 02:59 PM
bsampson
Jan 24, 2009 02:31 AM
pli
41
Feb 27, 2007 05:49 AM
Mikes01GSR
Aug 21, 2002 10:24 AM
The Kernel
Apr 14, 2002 11:55 AM
