question about my engine....
Old Feb 22, 2005 | 12:17 PM
NA JDM GSR's Avatar
Default question about my engine....
I forgot to put the oil dipstick back on and while i was driving there was smoke coming out of the engine so wen i got home i opened the hood and there was oil all over the place...so i was wondering how u can clean the oil from the engine??
Old Feb 22, 2005 | 12:22 PM
adseguy's Avatar
Default Re: question about my engine.... (GSR KiNg)
damn that sucks...use simple green and water...go over with water on the non electrical stuff with the car still cold. Get a brush of some sort and start scrubbing away. Elbow grease is what will get that off.
My engine bay is a little dirty..I'm thinking of taking the battery out on a nice hot day and just power washing everything. I'll put some plastic over the electrical stuff the best I can otherwise everything is getting wet and sprayed off! Then I'll let it dry off in the hot sun. Let it sit for a long time before starting the car.
Old Feb 22, 2005 | 12:26 PM
cnydc2's Avatar
Default Re: question about my engine.... (adseguy)
Simple Green works great, you could also try using foaming engine degreaser. Make sure you cover you distributor and any other major electronics and spray the engine down with the degreaser, then spray it off with a hose. After that I normaly use the simple green as a final cleaner.
Old Feb 22, 2005 | 12:38 PM
batmang yO!
Guest
Posts: n/a
Default Re: question about my engine.... (cnydc2)
^^ what they said. although I love simple green, I think purple power works better. IMO
Old Feb 22, 2005 | 12:44 PM
LSvtec03's Avatar
Default Re: question about my engine.... (Beavis)
simple green is supposed to work well, and i haven't tried purple power either. i'm going to try engine bright. any of these should work
Old Feb 22, 2005 | 12:50 PM
5 Speed AP2's Avatar
After you spit shine your engine bay and motor with either simple green, purple power, or watever you choose to use, you might see some oil residue evaporate/burn off your headers and other high temp components. Dont panic, its part of the circle of life, let em burn!
Old Feb 22, 2005 | 12:57 PM
shutupitsANDREW's Avatar
Default Re: question about my engine.... (5 Speed Dc2)
get that walmart engine degreaser, its cheaper and works better.
Old Feb 22, 2005 | 01:01 PM
RuskeR's Avatar
Full strength simple green
darkwater_ghost
Jun 18, 2009 02:01 AM
kornkid21792
May 16, 2009 06:33 PM
aznhoney
Jul 28, 2008 02:07 PM
civycoop
13
Jan 9, 2007 11:00 AM
