--Distributor Install---
Old Apr 7, 2005 | 01:25 PM
Arsenal's Avatar
Default --Distributor Install---
If when in taking out the old distributor I make a line where the old one was, then I should be able to put the new one in with out any timing issues correct?
Or does anyone have an how to?
Also I am throwing Code 9 which when searched hinted towards the distributor.
Modified by Arsenal at 10:38 PM 4/7/2005
Old Apr 7, 2005 | 01:43 PM
tilt's Avatar
Default Re: --Distributor Install--- (Arsenal)
It will probably be close enough if not the same, but the only real way to tell is to use a timing light.
Old Apr 7, 2005 | 01:44 PM
Arsenal's Avatar
Default Re: --Distributor Install--- (tilt)
Well I am having a timing belt and water pump install done in a couple of days so should be good until then,
However, am I in Limp mode now with CEL 9?
Old Apr 7, 2005 | 02:51 PM
projectTeG's Avatar
shouldnt effect timing to much if you get them in about the same postion....but id say use a timing light
Old Apr 7, 2005 | 04:48 PM
Arsenal's Avatar
Default Re: (projectTeG)
Well it comes in tomorrow so we will see how it goes.
Any tips ect?
Old Apr 7, 2005 | 05:30 PM
95lstegman's Avatar
Default Re: (Arsenal)
you're in FL. where exactly? i have an advance timing light, i'll do it for free. i'm in tampa (central and all the way west) and orlando (right in the middle), depending on day.
Old Apr 8, 2005 | 08:29 AM
Arsenal's Avatar
Default Re: (95lstegman)
Well I actually live in Sarasota, I think I am just going to align everything for now, then when it goes to Colin, Racing Integration on Monday for Timming Belt and Water pump, so the timing will all be set then.
One quick question, when I take the old one off, will I have to check the rotor to see what postion it is in then move the new one into the same position?
Old Apr 8, 2005 | 08:41 AM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">One quick question, when I take the old one off, will I have to check the rotor to see what postion it is in then move the new one into the same position?</TD></TR></TABLE>
YES! make it exact
Old Apr 8, 2005 | 09:00 AM
Arsenal's Avatar
Thanks, just wanted to make sure!
The rotor just swings around correct?
Old Apr 8, 2005 | 02:17 PM
tilt's Avatar
Yes.
the rotor is keyed into the camshaft, so there's really only one way to install it.
Old Apr 8, 2005 | 02:20 PM
carnifex's Avatar
Default Re: (tilt)
the keyway that fits into the cam itself is wither right or it is 180 degrees off. easy to figure out. i wish all of my motors had it.
Old Apr 9, 2005 | 10:20 AM
Arsenal's Avatar
Default Re: (carnifex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carnifex &raquo;</TD></TR><TR><TD CLASS="quote">the keyway that fits into the cam itself is wither right or it is 180 degrees off. easy to figure out. i wish all of my motors had it. </TD></TR></TABLE>
yes, as I was doing it, my dad watched over and looked at the Haynes. Then said all the steps are unessary. The rotor will only go in one way, or the other, so in only took me 5 mins, and the timing is unchanged.
Thanks for the help guys!
Warren_LowSol
Jan 18, 2018 12:22 PM
CaptivaBlue
Dec 3, 2005 01:12 PM
LoseRPunKx182
Jul 16, 2005 09:10 PM
johnbrooke86
Aug 23, 2004 04:49 PM
turbo Si
May 7, 2002 12:59 PM
