possible problems?
Old Apr 7, 2005 | 09:10 AM
Rs xtreme 415's Avatar
Default possible problems?
i think my teg is buring alot of oil and leaking oil. is it common for a teg to burn alot of oil?
also the car seemed like it would overheat, but i thought that was the tstat problem but not. also tried flushing the coolant and what not several times. still has that problem. help!
Old Apr 7, 2005 | 09:55 AM
Default Re: possible problems? (Rs xtreme 415)
Old Apr 7, 2005 | 10:34 AM
acro_acura94's Avatar
Hey i have the same problem w/my 1994 teg, GSR...what it is, for the burning oil, since u said its over-heating, u need to replace ur radiator, cuz since its overheating, ur frying ur piston rings, and thats what is letting oil bypas, and burning...Also, could be ur valve seals need to be replace....
As far as leaking oil..where at is it leaking?... like do u see some on the block, on the ground? ...cuz mine is the same as urs..the burning oil, is easy to fix, but not for urself to do, and money, i say its easy, cuz i already know the problem..but as far as leaking, mine sometimes leaks on the ground, then i see oil on the block where my headers bolt up too.. so im confused on there for myself too...............................
BTW....for ur burning oil, check ur PVC valve..but more likly ur fried ur piston rings..ok..hopefully i made some sense in this 5page speech!..
Old Apr 7, 2005 | 11:55 AM
projectTeG's Avatar
Default Re: possible problems? (acro_acura94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acro_acura94 &raquo;</TD></TR><TR><TD CLASS="quote">Hey i have the same problem w/my 1994 teg, GSR...what it is, for the burning oil, since u said its over-heating, u need to replace ur radiator, cuz since its overheating, ur frying ur piston rings, and thats what is letting oil bypas, and burning...Also, could be ur valve seals need to be replace....
BTW....for ur burning oil, check ur PVC valve..but more likly ur fried ur piston rings..ok..hopefully i made some sense in this 5page speech!.. </TD></TR></TABLE>
WHAT!????.....umm i dont think his radiator is bad,,..might be his water pump, ...also on the leaking oil check your seal on the valve cover...cam seals, oil pan, crank shaft seal...the oil buring problem get a compression and leak down test....some of your problems could be because your head gasket could possibly be bad
Old Apr 7, 2005 | 12:13 PM
CNSK's Avatar
Default Re: possible problems? (projectTeG)
more then likely your rings are fried or bad head gasket........for you heating problem could be thermostat or water pump...i doubt its your radiator......change your pcv valve also..........
Old Apr 7, 2005 | 05:07 PM
Default Re: possible problems? (CNSK)
the radiator is new well semi new now
there was a gasket leak and replaced.
hm as for oil it seems ok but it smoking when i drove it this morning. so i figured it that was oil burning due to leak. by the way the car is a ls
Old Apr 7, 2005 | 06:59 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rs xtreme 415 &raquo;</TD></TR><TR><TD CLASS="quote">the radiator is new well semi new now
hm as for oil it seems ok but it smoking when i drove it this morning. so i figured it that was oil burning due to leak. by the way the car is a ls</TD></TR></TABLE>
as for the over heating cheack you water pump and to see the heathlyness of the motor with a compression and leak down test
JDM02em2
Honda Civic (2001 - 2005)
10
Sep 24, 2008 06:41 PM
92BluEH-3
13
Dec 2, 2007 11:39 AM
vi3tromanc3r
Jan 23, 2007 09:45 PM
b18c5T
Jan 31, 2004 09:44 PM
