wheel pattern for DA integras??? HELP!
Old Apr 8, 2005 | 04:56 AM
92LsTegra's Avatar
Default wheel pattern for DA integras??? HELP!
will the bolt pattern 15x6.5 bolt on to a DA teg? or is it 15x5.5? buying bronze slipstreams need to know asap! thanks.
Old Apr 8, 2005 | 04:58 AM
92LsTegra's Avatar
Default Re: wheel pattern for DA integras??? HELP! (92LsTegra)
also is it 4x100 4x114.5 etc.? i know nothing about wheel demensions. any help is apreciated.
Old Apr 8, 2005 | 05:01 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LsTegra &raquo;</TD></TR><TR><TD CLASS="quote">will the bolt pattern 15x6.5 bolt on to a DA teg?</TD></TR></TABLE>
Hate to break it to you but 15x6.5 is a wheel size, not a bolt pattern. I hate to be a "search ****" but if I had a buck for every time this has been covered, I'd go ahead and retire.
Old Apr 8, 2005 | 05:14 AM
92LsTegra's Avatar
Default Re: wheel pattern for DA integras??? HELP! (Kendall)
haha dont i feel like an idiot.i should have known. but like i said im clueless when it comes to wheels. ill try more searching. thanks though.
Old Apr 8, 2005 | 05:25 AM
Racermech's Avatar
bolt pattern is 4x100 that mean 4 lugs with 100mm spacing. Look at an accord 4 lug you can see the difference with them being 114
Old Apr 8, 2005 | 07:02 AM
GrayT's Avatar
Default Re: wheel pattern for DA integras??? HELP! (Racermech)
Don't forget, the stock offset that come on DA's are +40.
Old Apr 9, 2005 | 09:30 AM
92LsTegra's Avatar
Default Re: wheel pattern for DA integras??? HELP! (GrayT)
ok thanks for all the help guys..
ruty
May 26, 2006 03:59 AM
loizenin
Mar 12, 2006 08:28 AM
LSVTEC 91 Civic
Welding / Fabrication
Oct 27, 2004 06:37 AM
Sohc Driver
May 7, 2002 05:58 PM
