Help! with battery.
Old Apr 7, 2005 | 05:28 AM
djtony5's Avatar
Default Help! with battery.
Well guy today I got an alarm installed with starter disable. And later on the night I went ahead and install my system. Everything went smoothly until I plug back in the negative battery wire and try to start up my car. I try starting up the car, but all I hear is click. Sooo I went and got a jumper cable to try to start the car up that way, but it did not work either. I was wondering if it is the starter disable alarm feature that preventing me from starting up my car or it is that my starter or alternator is dead.
Old Apr 7, 2005 | 05:57 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Help! with battery. (djtony5)
I would start out with disabling(sp?) the starter kill. See if you can start it then. I had my alternator poop out on me during the winter, but my car would start with a jump, so regaurdless of if your alternator is dead, your battery should be able to run your car for a little bit.
So, disconnect the starter kill, then try and start it. If that doesn't work, try jumping your car, with starter kill still disconnected.
The clicking noise does sound like a battery issue though, because thats what mine did when my battery **** on me.
anyways, hope this helps.
iTR
jorge59la
Sep 27, 2007 07:24 PM
01-0720
Feb 3, 2005 04:23 PM
rafiq7
Dec 14, 2004 07:46 AM
VisPreludeVtec
Dec 9, 2004 09:44 AM
See Are X
Mar 6, 2003 10:08 PM
